Old 01-02-2009, 05:21 PM   #29
down south , South Carolina
How do you determine what size shaver to buy?
I don't even know what they are used for, except for their name.
Dieselgrin is offline   Reply With Quote
Old 01-02-2009, 05:26 PM   #30
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
That's the problem...they are a single purpose tool.
You buy a rivet shaver to match the head size of the rivet...check out VTS for the 5/32" Rivet Shaver which is used with the 5/32" Olympic Rivets - they match the shape of original bucked rivets on Airstreams pretty well.
Shari
Old 01-02-2009, 09:07 PM   #31
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Originally Posted by goransons View Post
Thanks Gary,that's a great resource, also other related tools as well. For that price it would be worth ordering and giving it a try. Thanks!
It works. I bought one off ebay right after we got the trailer. Never had to use it on the trailer but played with it. Center carefully and practice till you get the depth you like. Works best with a battery drill set toward the high end of the low speed setting. It leaves a slight flat spot - but I don't have the official Olympic bit ($149 from VTS is all I've ever found). You just want to shave it as little as possible - and feed slowly - until you get the "sealed" look....
Good luck with it if you go that route...
Old 01-03-2009, 07:38 AM   #32
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Here's a link to a much earlier thread explaining the rivet shaver with Olympic rivets. www.airforums.com/forums/f381/olympic-rivet-removal-and-installation-23.html
The thread was posted before we had our server meltdown and the photos were lost. I updated the info and photos towards the end of the thread which explains the whole process. This should clear up any questions.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 01-03-2009, 08:59 AM   #33
Baltimore , Maryland
I need to throw in here.... a dremel can not and will not do the job of a shaver. The shaver addresses the ENTIRE head right down to the skin. It does not just remove the center shaft. Also, there are shavers and their are shavers. Olympic makes the one designed for there rivet. It is a worthy tool to own. The bit does not have a flat spot in it unless it has been used on something besides aluminum. It creates a perfect dome that is exactly the same size as the originals in less time than it takes to plug in a dremel.
Rivet Shaver Hind-Sight Ribs, Skins & Rivets 7 10-20-2006 09:28 AM
Rivet Shaver txairstream Ribs, Skins & Rivets 13 07-18-2006 11:48 AM
Operating rivet shaver Cruiser Ribs, Skins & Rivets 5 04-11-2004 02:35 PM
Rivet Shaver Bfrank Airstream Motorhome Forums 5 05-10-2003 02:46 AM
