Old 01-01-2009, 11:41 AM   #15
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Scott,
See this thread post 30 - maybe you could "roll your own" for the size job you have out of surplus parts.
http://www.airforums.com/forums/f36/...t-40328-3.html
Tools and Hardware,Page 13
Old 01-01-2009, 12:02 PM   #16
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Thanks Gary,that's a great resource, also other related tools as well. For that price it would be worth ordering and giving it a try. Thanks!
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 01-01-2009, 05:44 PM   #17
Ed Emerick's Avatar
1968 30' Sovereign
1959 18' "Footer"
1954 22' Flying Cloud
Brussels , Wisconsin
It's not so hot in WI in the Summer
Originally Posted by utee94 View Post
Wow, that is incredibly generous, Ed. You are clearly filled with The Airstream Spirit!
So far I've been shaving mine with a dremel. It is tedious and time-consuming. If I ever had to do a panel replacement, I would buy a rivet shaver, and just consider it the cost of Airstream repair.
Airstream Spirit? Naw I just love to use that tool. Hook up and escape the mid summer Texas heat ( I hear that Texas is 3 feet from hell in the summer) and come to WI. We'll shave rivets until the battery dies in the drill!
I'm NOT an old man.............
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
Ed Emerick is offline   Reply With Quote
Old 01-01-2009, 10:48 PM   #18
LLB21's Avatar
If you only have a few rivets ask an Airstream dealer to shave them down for you. I agree, they are costly to buy. I bought mine at Vintage Trailer Supply.
Louie
LLB21 is offline   Reply With Quote
Old 01-01-2009, 11:17 PM   #19
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Another thought Scott... I think shops that work on box bodies for trucks use the Bulb rivet.. (like Weisco, or other body shops that make the 10' cube vans, Uhauls and the like)...
Anyone around you that may grind the rivets for the trucks?
I too have some exterior patches to do.. (I have entertained a streetside skin repair.... but really don't want to). For just the patches, I'll use my Dremel... how about painters tape around the rivet to protect the skin?
Rain - about 36 degrees here... all the passes are closed though....
Marc
Old 01-02-2009, 07:32 AM   #20
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Marc
I know virtually nothing about this topic - just reading to try to learn in case I ever have to have a go at it!
But, it occurs to me that if you are going to try to use a dremel to dress the head, wouldn't a very thin metal shield - stainless or alum - with a hole in it sized to fit around the rivet head be a good way to protect the surrounding trailer skin against a slip of the dremel? I would think that if you tried to protect the trailer skin with tape, the dremel would go thru it like a shot.
I picture it as nothing more than say a 2" square of thin sheet metal (almost like a draftsman's erasing template) with a central hole to match the rivet head that you would just tape in place before starting to dress the rivet head.
Apologies if this sounds like rubbish - as stated i've never had occasion to do anything with rivets on my trailer - yet!
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 01-02-2009, 08:08 AM   #21
Not rubbish at all Brian, sounds like it would work.
Personally, I haven't had any real trouble with the dremel sliding off the rivet, it just takes extra care. But better safe than sorry, and creating a shield of some type would give you extra insurance against a slip.
I think Scott is going to check out the microcounterstop and shaving bit, so I'll be really interested to see how that works out for him.
Old 01-02-2009, 08:12 AM   #22
1972 25' Tradewind
Madison , Wisconsin
Dremel
I did a replacement window with a dremel. It did fine. Not quite as pretty as a grinder but then I am not that picky about a small flat spot on a rivet. If I were to do anything larger I would get the tool.
Smokin Camel is offline   Reply With Quote
Old 01-02-2009, 11:24 AM   #23
Wingeezer's Avatar
2005 30' Classic
Marcus,
One thing I don't understand in trying to follow this thread is what the "shaving" or dremel grinding really achieves?
Is the Olymic rivet not more or less a one-sided pop rivet style of fastener as opposed to a traditional bucked rivet?
If that is so, don't you wind up with a hole in the end and possibly a broken mandrel stub, which i guess would be snipped off?
How does this wind up eventually looking like a factory bucked rivet? Do you have to fill the mandrel hole with something and then grind or shave to simulate the appearance of a solid river?
Just wondering!
2005 Classic 30'
Old 01-02-2009, 12:04 PM   #24
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Pop rivet stems break off below vs Olympic rivet stems stick out beyond the head
The Olympic rivets are similar to pop rivets from the top side, except the stem breaks off and leaves a portion sticking out of the hole that needs to be cut/ground/shaved off. The stem is essentially the same size as the hole, so when it is shaved it kinda fills in the top - the gap between the stem & head is nearly invisible. A shaver puts a dome on the stem/head so that it looks like a bucked rivet when you are through.
Shari
Old 01-02-2009, 12:06 PM   #25
Wingeezer's Avatar
2005 30' Classic
Originally Posted by InsideOut View Post
The Olympic rivets are similar to pop rivets from the top side, except the stem breaks off and leaves a portion sticking out that needs to be cut/ground/shaved off. The stem is essentially the same size as the hole, so when it is shaved it kinda fills in the top - the gap between the stem & head is nearly invisible. A shaver puts a dome on the stem/head so that it looks like a bucked rivet when you are through.
Shari
Shari - Ahaaa! Now I understand! Thanx ......... Brian.
2005 Classic 30'
Old 01-02-2009, 02:59 PM   #26
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Also use Vulkem on each Olympic Rivet. This will ensure a water tight seal.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 01-02-2009, 03:17 PM   #27
InsideOut's Avatar
1956 22' Safari
Images: 108
Lightbulb
...and DON'T buy the Olympics w/ washers. The rubber washers deteriorate over time - like rubber bands, which means you will have gaps for water to get in where the washer was.
Shari
Old 01-02-2009, 03:31 PM   #28
1998 28' Excella
Dolores , Colorado
Shari:
Thanks for clarifying the Rivet Shaver. I am like Wingeezer. I have been following this thread and I keep wondering what the h--- is a Rivet Shaver. Fortunately I have never had the need for one, even with my 71 model.
Have a good year.
Member Four Corners Unit/CAC
WBCCI # 10105
AIR # 28748
dogpound is offline   Reply With Quote
Rivet Shaver Hind-Sight Ribs, Skins & Rivets 7 10-20-2006 09:28 AM
Rivet Shaver txairstream Ribs, Skins & Rivets 13 07-18-2006 11:48 AM
Operating rivet shaver Cruiser Ribs, Skins & Rivets 5 04-11-2004 02:35 PM
Rivet Shaver Bfrank Airstream Motorhome Forums 5 05-10-2003 02:46 AM
