Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 07-04-2006, 09:25 PM   #1
txairstream
Profile:  1972 27' Overlander
Chappell Hill , Texas
Rivet Shaver
Hello, can anyone tell me where I can purchace a rivet shaver from?
txairstream is offline   Reply With Quote
Old 07-04-2006, 09:30 PM   #2
peegreen
peegreen's Avatar
Profile:  1998 31' Excella 1000
South Berwick , Maine
Try Vintage Trailer Supply http://www.vintagetrailersupply.com/...Code=VTS%2D177
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 07-04-2006, 09:54 PM   #3
txairstream
Thank you. they are proud of it.
Old 07-04-2006, 10:26 PM   #4
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
aircraft tool supply www.aircraft-tool.com has them for $520.
you could try a micro stop countersink (pg 47) and a shaving bit(pg 48).
total cost about $50.
Michelle
I'm not afraid I learned to drive in Washington, DC
Sarah
Ruby, (05 BMW R1200RT) serviced and put to bed for the winter
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Classic 31 w/dinette, solar)
http://Michelles-Adventures.US
Old 07-06-2006, 12:14 AM   #5
scottanlily
Profile:  1960 24' Tradewind
santa barbara , California
Hello txairstream,
The price from vintage trailer supply seems to be the going rate.I thought they were 20 bucks higher before .I would invest if you are shaving
hundreds of rivits ,they add up really fast .Yes too much money but sell it when your done.Many buyers waiting .
Scott
scottanlily is offline   Reply With Quote
Old 07-06-2006, 10:36 AM   #6
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Inland RV also has the correct shaver.
Same going rate price, as other venders.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Inland RV Center, In is online now   Reply With Quote
Old 07-10-2006, 04:15 PM   #7
Aerowood
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
rivet shaver
You could use the following part number tools from www.ustool.com
1) TP61B microstop 31.00
2) TP61CT-1 5/16" skirt 8.50
3) TP143-5/16 rivet shaver bit 27.65
Rivet shavers are designed to be used at a high rpm so an electric drill will not be fast enough. Use of an air drill with at least 3000 rpm would be better
Old 07-10-2006, 05:57 PM   #8
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
Be aware that aircraft rivet shavers are not what you use to profile olympic rivets. Aircraft shavers cut the rivet head flush with the surface and are designed to use with flathead rivets. The Olympic cutter is concave (hence its cost) and cuts the rivet head in a button shape after the protruding stem is removed with side cutters. Aircraft rivet tools are fine, but you need the special bit. Most people just buy the cutter complete. You'll have to bite the bullet to shave the rivet!
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 07-11-2006, 01:35 AM   #9
scottanlily
I understood that the olympic shaver tool uses a drill to operate ,with aluminum especially I believe it wouldn't take much to profile that rivit stub .
not alot there after the side cutters do their part ,as your smoothing down
a very small protrusion .Aliminum olympics are pretty soft .
Scott
Old 07-11-2006, 08:54 AM   #10
Aerowood
Aerowood's Avatar
Arvada , Colorado
Most microstops and dedicated (aircraft ) rivet shavers have at least 1/2" adjustment, more then enough adjustment to raise them away from the surface of the skin in order to shave just the stem. Granted the cutters are flat but the rivet stem is only around 1/8" in diameter and the difference between a radiused cut and a flat cut on a1/8" stem is really going to be negligible and the cost is alot less for the person working with a tight budget.
Old 07-11-2006, 10:10 PM   #11
scottanlily
I agree on the better value ,but the idea is to get the rivit to have the
same head profile as a factory airstream rivit .Although I have used a dremel
extra carefully on the ones I have done ,so It would work for me .If I was
going for a full exterior pro job I would invest in the rivit shaver for the airstream rivit profile .But 200 bucks is alot of money ,no arguement there.
Scott
Old 07-12-2006, 11:04 PM   #12
Excella CM
Excella CM's Avatar
Venice , California
I bought an Olympic shaver when I replaced two rear panels on the old Excella. I don't hesitate now to remove a rivet because I can replace it and make it look original. Expensive, but a once-in-a-lifetime purchase I wouldn't do without.
Old 07-18-2006, 09:49 AM   #13
txairstream
Thanks everybody for replying to my very first question on the forum. Andy I talked to Inland RV last night and will be ordering it soon as I get a complete list of everything I need. I have two Airsteams (kinda went crazy) 71 Safari and a 72 Overlander. If someone could let me know how to attach photos I will post some. Thanks
Old 07-18-2006, 12:48 PM   #14
kitchenclose
Profile:  1966 17' Caravel
Seattle , Washington
Could you use a Dremel tool to shave off the rivet heads?
kitchenclose is offline   Reply With Quote
Olympic rivet removal and installation PeterH-79MH Ribs, Skins & Rivets 38 08-13-2008 03:31 PM
Best rivet tool? Andy R Ribs, Skins & Rivets 9 09-24-2006 08:36 AM
rivet tools maznblu Ribs, Skins & Rivets 12 05-31-2006 06:51 PM
How durable is a Cyclo polisher? What about a rivet shaver? Andy R Cleaning, Stripping & Polishing 9 04-10-2004 10:03 PM
Rivet Lounge PeterH-79MH Our Community 68 09-25-2002 12:22 AM
test
