Old 08-06-2011, 10:22 PM   #1
esmaytum's Avatar
1963 28' Ambassador
1978 28' Ambassador
Boerne , Texas
Rivet removal question
I need to remove the big rivets from the bottom that holds the belly. The belly goes around the frame and tucks up under the outer shell. The belly had a bunch of tears where the frame came through it so I have to replace the whole thing. My question is how do I get those big suckers out, and once I do, what is the best replacement. (5052-H32 ?) I'm going to buy the rivet set from VTS but they are out of stock at the moment. All suggestion are welcome, I'm a newbie (2wks into this).
esmaytum is offline   Reply With Quote
Old 08-07-2011, 04:06 AM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
I've used these to replace a few missing belly pan rivets:
Large Flange Rivets
Old 08-07-2011, 05:32 AM   #3
Dan@LED4RV's Avatar
Denton , North Carolina
drill or grinder
I always drill them or use a grinder. Once you grind them some, you may can use a chisel to cut them the rest of the way off.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Steel / Aluminum wheel question polarlyse Wheels, Hubs & Bearings 12 05-29-2011 07:49 PM
Rivet Tutorial TX_Argosy Ribs, Skins & Rivets 5 05-24-2011 04:19 PM
1980 Caravelle axle question Seymour Axles 5 05-14-2011 08:28 PM
Where to oil a rivet gun? DanielB Ribs, Skins & Rivets 6 04-30-2011 12:37 PM
Blasphemous question woytovich General Repair Forum 15 04-09-2011 08:36 AM
