Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 09-26-2008, 08:20 PM   #1
Profile:  1965 17' Caravel
Southern , Connecticut
Rivet Question - Awning Installation
OK, my first big miss in the renovation.
After re-installing the shell, installing bubble foil insulation and installing the upper interior skins, I remembered the awning rail.
I'm a bit pressed for time and would like to avoid removing the interior skin again and cutting through the bubble foil.
Would Olympic Rivets or Rivnuts properly hold a 7' awning on a '65 Caravel? Or am I better off pulling the inner skin, cutting the insulation and bucking? (probably a 3 hour job). Are any of the solutions better in terms of preventing leaks?
John
main thread: Renovation of gutted 1965 Caravel
65CV is offline   Reply With Quote
Old 09-26-2008, 08:54 PM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
John
John, I hate to say this, but you're better off bucking the rivets in the awning rail.
While Olympic rivets will probably hold fine, they might leak over time.
Bucked rivets and a dab of vulkem over each on the inside will surely prevent all future leaks.
Uwe
www.area63productions.com
Old 09-26-2008, 09:00 PM   #3
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
If it were mine, I'd use Olympics dipped in Vulchem.
"Not all who are laudering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 09-26-2008, 09:03 PM   #4
Airstream Registry
John, I've been following your restoration and you're doing such a good job. I hate to say something negative, but to me the questions become-- how long do you plan to have the trailer, AND, do you ever want to have to do this again?
As usual, Uwe is right. He's been here before and is wise in the ways of vintage trailer restoration.
It might end up being a slight pain, but doing it correctly now means NEVER second-guessing yourself in the future.
I'm enjoying your great work, keep it up, and good luck!
Old 09-27-2008, 04:47 AM   #5
I'll do it right
Thanks for all the replies and Marcus' compliments.
If the weather holds, I'll buck it on today. I don't want to worry about one good gust of wind distorting the legs of an Olympic rivet.. causing a leak.. rotting my new floor.. making me redo this again in 10 years.
Without overhead cabinets or lighting in place, now is the easiest time to do it. I just hate redoing stuff!
John
Olympic rivet removal and installation PeterH-79MH Ribs, Skins & Rivets 68 12-28-2009 03:48 AM
Rivet Question Dennis Clark Ribs, Skins & Rivets 14 05-27-2004 11:11 AM
Rivet Question JMoy Ribs, Skins & Rivets 4 09-27-2003 07:43 AM
New Awning Installation Don Tucker Awnings 2 07-30-2003 12:12 PM
Zip Dee Awning installation thenewkid64 Awnings 3 04-19-2003 10:08 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
