Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 09-24-2003, 09:00 PM   #1
JMoy
JMoy's Avatar
Profile:  1966 17' Caravel
Redmond , Washington
Rivet Question
I am a restoring my 66 Caravel and it is time to start drilling out rivets for parts replacements. I noticed that some rivets have rounded heads and some have convex heads with a hole in the middle. Are these different rivets? I want to replace the rivets with the correct type.
Thanks for the help.
Jerry
JMoy is offline   Reply With Quote
Old 09-24-2003, 09:31 PM   #2
markdoane
Profile:  , Minnesota
Images: 59
Rivets
The convex ones with the hole in the center are regular pop rivets like you buy at any hardware store (be sure to get all aluminum, some come with steel shanks), the rounded ones are solid rivets. If you remove these you need to replace with "Olympic" rivets, which are more expensive, and leave a stem which needs to to clipped off and filed down
Old 09-24-2003, 11:07 PM   #3
Rog0525
5 rivets, 1 loose screw
Rog0525's Avatar
Profile:  1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Olympic rivets
Here's a very good thread complete with photos that you might find helpful:
http://www.airforums.com/forum...olympic+rivets
Rog0525 is online now   Reply With Quote
Old 09-27-2003, 02:49 AM   #4
fabofabo
Profile:
Thanks for the peek! Quite insightful!
Fabofabo
fabofabo is offline   Reply With Quote
Old 09-27-2003, 07:43 AM   #5
JMoy
JMoy's Avatar
Thanks for all the info. I are ready to start riveting.....
Jerry
Olympic rivet removal and installation PeterH-79MH Ribs, Skins & Rivets 38 08-13-2008 02:31 PM
rivet tools maznblu Ribs, Skins & Rivets 12 05-31-2006 05:51 PM
Rivet holes and Door Latches JimC Doors & Locks 1 10-17-2003 10:12 AM
Bellypan Rivet Question Creampuff Our Community 7 01-22-2003 06:42 PM
