05-31-2011, 04:11 PM
1968 20' Globetrotter
fair oaks
Rivet Hole Repair
In getting my AS ready for polishing, I removed the AIRSTREAM name plates on the front and rear. When drilling out one of the rivets I must not have had the drill lined up properly and I ended up with a larger hole (see pic). Unfortunately, it was at one of the corners and I am concerned that the nameplate will eventually pull up at this location.
My question: Is it possible to repair so that a rivet will go in securely at this spot or do I just live with the mistake and use lots of adhesive?
Any suggestions will be most appreciated.
05-31-2011, 04:47 PM
1977 25' Tradewind
Waskesiu Lake
, Saskatchewan
You could use a rivet with a larger diameter shank, but the same size head as the other rivets that hold the nameplate on (first choice...).
Another option is to put a dab of "JB Weld" behind the nameplate where the rivet hole is and then put the rivet through the hole and secure it (second choice). I suspect the JB Weld will seal & secure it OK. It's not like it bears any stresses really.
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
05-31-2011, 05:03 PM
1979 23' Safari
1954 29' Liner
Orange
You could use an olympic rivet at all four corners. Properly finished they look almost like bucked rivets. Or if you have the inside skin off put a small piece of aluminum inside the bucked rivet.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
05-31-2011, 05:09 PM
1960 33' Custom
Athens
, Georgia
Easy fix, use a washer behind the rivet.
05-31-2011, 05:38 PM
Ottawa
, ON
A SS or AL washer, I guess...
05-31-2011, 05:53 PM
2002 25' Safari
Dewey
Since a name plate will cover this hole in the skin, just use an olympic rivet. The legs of the rivet are more then wide enough when extended to get a good grip.
Richard
06-01-2011, 02:46 PM
fair oaks
In the future, what can I do to prevent making the same mistake?
06-01-2011, 02:57 PM
1979 23' Safari
1954 29' Liner
Orange
Not to be a smart aleck, but be careful.
Bill
06-01-2011, 03:09 PM
1960 24' Tradewind
Austin
avoiding rivet drilling mistakes
an experienced aircraft worker gave me some advice--
1. use a machinists punch to mark the center of the rivet dome; remove paint or other materials first. get this as accurate as possible so the drill bit doesn't wander.
2. use a small drill say 3/32 or 1/16" to drill through the dome, but hardly into the shank.
3. switch to a 1/8" drill to widen the hole, but stop before going past the head. Don't drill into the shank at all. This will eliminate damage to the sheet metal parts
4. insert a 1/8" punch or old 1/8" drill( the smooth part where the drill chuck grabs it). rock the punch/bit back and forth until the head of the rivet breaks off.
5. punch out the shank.
This would be best practice for a high strength repair. For cosmetic rivets I skip the 3/32 drill step. It takes practice and judgment to get the 1/8" hole the right depth. If the hole isn't centered the head won't break off clean and a small chisel must be used to knock the rest off. That will probably damage the sheet metal..
Vintage Trailer sells 5/32 shank 1/8 head rivets.. clean up the holes with a #20 drill bit which will alleviate the damage.
06-01-2011, 08:04 PM
Hollis
, New Hampshire
If the interior skin is out, I've had good luck taking a sharp chisel, knocking off the stem in the back and popping the rivet head out with a nail set.
