Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 12-05-2017, 06:14 PM   #1
1970 25' Caravanner
Incline Village , Nevada
Rivet gun purchase
I am involved in a shell off renovation and will need to rivet at some point. Was hoping for advice on what tools to buy. Considering Harbor Freight air hydraulic riveter as pictured below. They sell 1/4" ($69.99) and 3/16" ($39.99). Would I need the 1/4" for any Airstream use or can I get away with the cheaper one?
Name:	Harbor Freight riveter.jpg
Also came across these on Craigslist but am not sure if this would be a good purchase. Seller is listing all for $350 or just the air riveter for $60...should I jump on that?
ID:	300400Click image for larger version
Name:	rivet parts.jpg
ID:	300401Click image for larger version
Name:	rivet parts 3.jpg
Jeremy9107 is offline   Reply With Quote
Old 12-05-2017, 07:09 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Cheaper should work fine
Old 12-05-2017, 07:32 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
I'm not aware of any 1/4" diameter rivets in the Airstream. I have a 3/16" riveter and use it all the time. It is for pulling "pop" rivets such as the belly pan and interior skins.
The exterior skins are solid rivets "bucked" tight by hammering and squishing them. The Craigslist tools appear to be air riveters for that purpose, along with the bucking bar. You need access to both sides of the rivet to install solid rivets.
Bottom line, you will likely need both tools.
David
Old 12-05-2017, 08:02 PM   #4
Registered User
DDickey's Avatar
1957 22' Custom
Lago Vista , Texas
Rivet Tool
$350 seems a bit steep for the CL find. I love my cheap Harbor Freight rivet tool, it's gone the distance on my Full Monty
DDickey is offline   Reply With Quote
Old 12-05-2017, 09:03 PM   #5
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
I purchased this gun, good reviews, another owner recommended added a swivel air connector. The swivel really helps the right angle air input.
I have shot a lot of rivets, somewhere around 1500 rivets. 82% 5 star rating at this seller.
sgschwend is offline   Reply With Quote
Old 12-06-2017, 12:18 AM   #6
1970 25' Caravanner
Thanks to all who responded.
Was thinking that Harbor Freight riveter could be used for pop rivets and buck rivets by exchanging the nosepiece but guess I was wrong.
So think I'll get the cheaper Harbor freight one for pop rivets (it comes with nose pieces for 3/32, 1/8, 5/32 and 3/16) and the CL one for buck rivets.
Old 12-06-2017, 05:39 AM   #7
2016 25' Flying Cloud
Holly Springs , Mississippi
The one on CL will be cumbersome and heavy. It is gross overkill. Take a look at the ones on Aircraft Spruce's website for those that are much lighter and easier to maneuver, then search for a used one on CL or ebay (or buy a new one if you like).
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 12-06-2017, 07:51 AM   #8
Registered User
DDickey's Avatar
1957 22' Custom
Lago Vista , Texas
Buck rivets
Get the Harbor Freight tool for pop, and the Vintage Trailer Supply tool for buck:
https://www.vintagetrailersupply.com...-p/vts-630.htm
Old 12-06-2017, 02:35 PM   #9
Dingo Girl's Avatar
1967 17' Caravel
Oak Creek , Colorado
I bought the VTS buck riveter & it has been trouble free.
Just use it at far less air pressure than they recommend.
Dingo Girl is offline   Reply With Quote
Old 06-14-2018, 03:08 PM   #10
2011 27' FB Flying Cloud
Bradenton and Saluda , Florida & North Carolina
HELP!!!!!! Lost an outside rivet on the front compartment door! Is there anyone in The Hendersonville NC area that could help a rivet-stranded Airstreamer with a rivet replacement? I have no rivets, nor rivet tools☹️ Thanks!
ncbambi is offline   Reply With Quote
Old 06-14-2018, 03:49 PM   #11
2007 22' International CCD
My favorite go-to emergency tool on the road is my favorite big box home improvement store's credit card.
A decent temporary fix can be made with a hand-operated pop rivet tool and some all-aluminum pop rivets from the hardware department. A rivet tool and an assortment of pop rivets will set you back a few bucks, and is a very handy thing to keep in the AS.
For the interior, you need 1/8 shank rivets. For exterior stuff 3/16 is the usual size.
If it's wet out, a small tube of DAP vinyl caulk or a bit of Gorilla brand tape will seal out water until you can get a better repair done...
Old 06-19-2018, 02:32 PM   #12
1970 25' Caravanner
ncbambi. hope you fixed your situation.
agree with rmkrum. stuff you need is likely at home improvement store. although my local Home Depot and Lowes are quite scarce with aluminum rivets. what they do have is steel. and had a tough time finding hand riveter.
Ace Hardware was a better place for these items.
As a follow up to original post. Bought the Harbor Freight air riveter and never opened the box. Ended up returning it as had no problem hand riveting hundreds of pop rivets of all sizes with a handmedown handriveter from my grandfather. Did end up buying buck rivet bar and air riveter for buck rivets however. Was not as tricky as I had thought.
Old 06-19-2018, 06:24 PM   #13
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Gee Jeremy: I bet you have a really firm handshake after popping all those rivets by hand.
My father had strong hands due to milking cows by hand at the family farm.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 06-19-2018, 06:31 PM   #14
toastie's Avatar
1955 22' Safari
Great Lake State , .
Highly recommend a good rivet gun, don't waste your money at Harbor Freight....
https://aircraft-tool.com/shop/searc...ookieSupport=1
https://aircraft-tool.com/shop/searc...ORY=Rivet+Sets
https://aircraft-tool.com/shop/search.aspx
toastie
toastie is offline   Reply With Quote
Old 06-19-2018, 06:39 PM   #15
2017 28' International
Jim Falls , Wisconsin
I bought a rivet gun and assortment of rivets from an AS store. It’s not a power tool. That was pretty expensive. Just google airstream rivet guns. I think gun and rivets together was about $75. But for a big project I would have definitely purchased a power gun.
Daquenzer is offline   Reply With Quote
Old 12-21-2019, 12:42 PM   #16
2007 25' Classic
San Luis Obispo , California
Harbor Freight Riveter
I just bought the 3/16" air hydraulic riveter. The instructions say to prime it by turning it over, removing the piston assemble and adding hydraulic oil to the top of the housing. The instructions reference #15 but there is no #15 on the illustration. How far up do I fill it? To the top of the Ait Piston Locknut on the bottom where the piston shaft goes in? The top of the whole housing or air cylinder seems way too much. Thanks in advance for your help!
slofoks is offline   Reply With Quote
Rivets, rivet gun and brazier gun ? Gaël Ribs, Skins & Rivets 33 03-27-2014 08:27 AM
Rivet Gun Size and Brand JimGolden Ribs, Skins & Rivets 5 11-23-2005 08:48 PM
Rivet gun overlander76 Ribs, Skins & Rivets 1 08-03-2003 06:22 AM
proper rivet gun for AS oldvws Ribs, Skins & Rivets 12 11-23-2002 09:04 PM
