Old 03-24-2011, 11:30 AM   #1
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Rivet gun ?
I am almost up to re-installing the interior liner in our 54 cruiser and looking for a inexpensive pneumatic rivet gun. Anyone have a good source?
I have been looking at them on ebay and wondering if the $50.00 models will make it through the job? I really don't want to buy the $200 ones if I don't have too. My hands will probably be worn out if I don't get something besides my hand operated one.
Here is one of the Ebay units:
Pneumatic Air Pop Rivet Gun Tool Squeezer Riveter Kit | eBay
Thanks Doug
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 03-24-2011, 11:33 AM   #2
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
I got mine at Harbor Freight for I think about $29.00 works just fine so far.
I must have got mine on sale here's the price now.
http://www.harborfreight.com/3-16-in...ter-93458.html
SilverHoot is offline   Reply With Quote
Old 03-24-2011, 11:52 AM   #3
airstream4's Avatar
1997 34' Limited
1963 22' Safari
Troy , Michigan
Interior rivets are easier than exterior, but when doing more than 5-6 the air operation is needed! exterior I hook up the air with no hesitation! I purchased the Harbor freight unit for around $29. Harbor freight always has new sales and their Sunday flyers have 20% off coupons. I have installed over 700 exterior rivets with the Harbor freight unit which is still going strong! Done interior on three trailers also.
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
airstream4 is offline   Reply With Quote
Old 03-24-2011, 02:48 PM   #4
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Thanks for the links! I will check it out this weekend.
Old 03-24-2011, 03:01 PM   #5
Images: 59
Another vote for Harbor Freight. Mine is so beat up you can hardly tell what color it is. Needs a little PM once in awhile.
Really make the interior wall replacement easier and neater. Got mine at the store in Minneapolis, but there's one in the Signal Hill Shopping Center also.
markdoane is online now   Reply With Quote
Old 03-24-2011, 03:59 PM   #6
Someday'59's Avatar
Powder Springs , Georgia
Images: 18
One note about the Harbor Freight pneumatic riveter... it seems like the mandrels have a tendency to get stuck...just make sure you hear it fall out the back before you shoot another rivet.
~Lynnetta
my restoration & travel blog:
http://someday1959.blogspot.com
Someday'59 is offline   Reply With Quote
Old 04-01-2011, 12:51 AM   #7
Star-Man's Avatar
1953 21' Flying Cloud
Encinitas , California
It's not pneumatic, but I got a drill attachment from Mcmaster-Carr that works pretty well. The part number is 98716A100.
Star-Man is offline   Reply With Quote
Old 04-01-2011, 04:21 AM   #8
Baltimore , Maryland
you said "exterior" Are you are saying you installing pop rivets on the outside of the trailer? You mean like replacing bucked rivets with ones you pull? Could you explain?
Tim, I am often the voice of the other side. I do not use air riveters except to set a solid bucked rivet. I prefer to feel the rivet tension as it is pulled. I know many swear by the air riveters, but in my shop we do not use them. When hand pulling, you have time to adjust the angle or inward pressure over an instant zap. I have used the pneumatic ones before, but found I had many rivets set incorrectly and that was why I went back to the old school method. Doing it this way also keeps my hands strong. Just my opinion, not always the correct one, but works for me.
Old 04-02-2011, 06:42 AM   #9
airstream4's Avatar
1997 34' Limited
1963 22' Safari
Troy , Michigan
[QUOTE=62overlander;972328]you said "exterior" Are you are saying you installing pop rivets on the outside of the trailer? You mean like replacing bucked rivets with ones you pull? Could you explain?
When I say exterior I am referring to 5/32" Olympic Shaveable Rivets
I have never tried to buck rivets, requires two people plus access to both sides. Half of my exterior rivets were with exterior access only.
Paul
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
Old 04-02-2011, 07:43 AM   #10
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Thanks for all the rivet information everyone, I have used a few olympic rivets on the outside only when i could not get help with buck rivets and then i made sure to volkume the inside for leaks. I have done a lot of pop rivets by hand on the belly and other non visible areas. I was not sure about the Buck rivet process at first but have found it really is not any harder then a pop rivet but just need 2 people.
Frank I do like your thought of keeping your hands tough and getting a good feel of the rivet. I did order a pneumatic gun from harbor freight, it's always good to get new tools:-)
Doug
Old 04-02-2011, 07:48 AM   #11
I agree with Frank, I've probably pulled a thousand interior pop rivets in my trailer so far, and I used the pneumatic riveter for a couple hundred of them, but found that I preferred the "feel" of hand-squeezing the rivets with a manual rivet puller. It's up to you, but if you do go with a manual one, make sure you buy a high-quality one. I had a cheap one that died pretty quick on me, then I ordered the one from Vintage Trailer Supply and it has been a very solid tool.
Good luck!
Old 04-02-2011, 08:07 AM   #12
Maniacal Engineer
barts's Avatar
Menlo Park , California
If I'm using stainless pop rivets in any quantity, I'd want a air version; I've broken the manual ones that way. I like using stainless rivets on areas under more load...
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Wall Rail Systems funkill Upholstery, Blinds, Walls & Interior Finishes 16 08-27-2012 04:50 PM
50's Hehr roof vent lifter arm rivet tool vintageair Roof Vents, Skylights & Fans 12 06-29-2011 01:37 PM
Silicone tent seam sealant over rivet heads jayg Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 03-10-2011 10:25 AM
Need help removing rivets. Breadbug Windows & Screens 16 01-19-2011 08:11 PM
