Old 04-11-2010, 09:42 AM   #43
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
My 71 was put together with "A" rivets, I have looked at several trailers and it looks like 69 was the change over year but I wouldn't bet any money on it. I have however used "AD" rivets on 75% of my restoration/rebuild. I have used "A: rivets to reinstall my window frames because the frames are so soft.
Kip
Aerowood is online now   Reply With Quote
Old 04-11-2010, 09:50 AM   #44
Aerowood's Avatar
Arvada , Colorado
Originally Posted by mimiandrews View Post
There might be two kinds of Cherry rivet pullers out there. The older Cherry rivets had a knob on the stem which engaged a special puller.
You're showing your age here, or maybe I am. I haven't seen the Cherry Rivets with the bulbed stem since the 70's, are those still floating around?
Old 04-11-2010, 02:14 PM   #45
CAPTNDAVIE's Avatar
Hopefully I will be getting or at least get a look at the Cherry guns he has today. I will try to get a pic and will post it when I do.
CAPTNDAVIE is offline   Reply With Quote
Old 04-12-2010, 08:46 AM   #46
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
I haven't seen a single AD rivet in our '66 Safari. Don't know when they switched, because we're still really new to this Airstream thing. (Aircraft sheet metal with no FAA--lovin' it).
Age isn't a bad thing. Getting older is a privilege. Lotsa people in the graveyards who aren't getting to do it!
Old 04-12-2010, 08:43 PM   #47
CAPTNDAVIE's Avatar
Cherry Rivet Guns
Here they are.
Old 04-13-2010, 09:27 AM   #48
Aerowood's Avatar
Arvada , Colorado
I've never used one of those, actually never seen one either. Give it a try and see what happens.
Old 04-13-2010, 11:55 AM   #49
CAPTNDAVIE's Avatar
I figured out that it is a Cherry GH780. They even had a manual for it online.
Rivet Gun Size and Brand JimGolden Ribs, Skins & Rivets 5 11-23-2005 08:48 PM
Factory rivet vs. repair rivet yukionna Ribs, Skins & Rivets 32 09-08-2003 04:41 AM
Rivet gun overlander76 Ribs, Skins & Rivets 1 08-03-2003 06:22 AM
proper rivet gun for AS oldvws Ribs, Skins & Rivets 12 11-23-2002 09:04 PM
