Old 03-31-2009, 04:09 PM   #15
Originally Posted by soldiermedic View Post
The site isn't as good as just calling the number and talking to him directly. Ask specifically for the 3x gun, rivet set, and bucking bar. You can't go wrong for the price with toolsez.
Steve
And I'd ask for an assortment of rivet sets. Certainly the 5/32 universal, and a 1/8 universal as well. Kip could probably recommend a few more common ones that would be good to have. I you notice, in the complete sets that he's selling on that web page, he's include 12 different die. Some of them appear to be offset, which are useful in various applications. You'd probably never need all 12, but there might be some common ones that it would make sense to be sure the guy throws in, if you choose to go with toolsez.
Old 03-31-2009, 04:36 PM   #16
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
For the most part a short (3 1/2") 5/32 rivet set will work for 99.5% of the riveting that a typical Airstreamer will use. The only other sets, would be a short 5/32 offset, a flush set, and maybe a 1/8 short. Stay away from long sets and dogbone sets as they obsorb energy from the gun and you might have to step up to a 4X to overcome that offset.
Old 06-24-2009, 05:18 PM   #17
floridartist's Avatar
1973 29' Ambassador
Fort White , Florida
After reading this rivet gun forum, I think I must be the cheapest of all, but here is my question, I bought a ARROW Rivet gun at Home Depot, it no longer cuts or pops the rivets, is there an adjustment on this handgun?
floridartist is offline   Reply With Quote
Old 06-24-2009, 07:09 PM   #18
Lothlorian's Avatar
Loganville , Georgia
This is what I used and it did not cost me over $50. I has done the job for me. I bought it at Harbor Freight. You can order online.
- Harbor Freight Tools - Quality Tools at the Lowest Prices
Check it out
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 06-24-2009, 08:11 PM   #19
toastie's Avatar
1955 22' Safari
Great Lake State , .
Try 2602A | Aircraft Tool Supply
toastie is offline   Reply With Quote
Old 06-24-2009, 08:44 PM   #20
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Originally Posted by augier View Post
Ok so I have been looking around for the cheapest rivet gun for the solid rivets around the bottom of the exterior. Now time is getting closer and I was looking through my dads tools and he has a air hammer that has a speed adjustment on the bottom....If I get the right tip and a bucking bar localy what would be the diffrence to the really expensive rivet gun ?
3X RIVET gun is your best bet. Adjustable air valve as well.
Michelle TAC MT-0
Sarah, Snowball
Old 06-24-2009, 09:02 PM   #21
Lothlorian's Avatar
Toastie:
I like that Aricraft supply. That is a nice rivet gun for a decent price.
Brian
Brian & Adrienne
Old 06-24-2009, 09:29 PM   #22
1972 Travelux Princess 25
Cobourg , Ontario
I have done this. Helped a friend restore a Piper Cub using a cheap air chisel to set the rivets.
Cut the pressure down and go real slow with the air chisel. You want it to go "putt,,, putt,,, putt". 3 or 4 "putts" to set each rivet.
You will need the appropriate tip and bucking bar.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 07-06-2009, 08:49 AM   #23
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Apples vs Oranges
The 3X Rivet guns (we got ours at Brown Tool) are for bucked rivets. It sounds like the Arrow tool you bought at Home Depot is for pulled rivets....don't know about any adjustments on the Arrow, might be time for a new one ~
Shari
Old 07-06-2009, 12:04 PM   #24
Keymar , Maryland
Just where are the rivets on a cub?
Michelle TAC MT-0
Sarah, Snowball
Old 07-07-2009, 07:06 PM   #25
Cobourg , Ontario
We were installing a new firewall. It may not have been a Piper Cub but it was a small high wing monoplane of some kind. This was 20 years ago.
Old 07-08-2009, 05:40 PM   #26
1965 26' Overlander
Edgewood , New Mexico
After alot of searching, here is another kit I'm thinking of getting to get me started:
www.http://www.aircraft-tool.com/shop/detail.aspx?PRODUCT_ID=3XKT&ReturnPage=/shop/search_result.aspx?PageNo=1
Anyone here familiar with ATS rivet guns, or can recommend another starter kit?
Thanks!
JP
AgPnut is offline   Reply With Quote
Old 07-08-2009, 08:37 PM   #27
Ottawa , ON
I'll be replacing the screen door on my TT in a week or so. There are two hinges, each with six rivets: 3 bucked, and 3 pop style, as you can see in the image below:
I don't have a rivet gun or bucking bar. Will I be OK using pop rivets on all six per hinge? The three pop rivets are used because the inner three are hidden behind the aluminum door panel on the side you don't see in the image.
Old 07-08-2009, 08:43 PM   #28
Keymar , Maryland
The inside ones are bucked due to clearence. Pop rivets stick out too far. They can be used on the inside since they stick into the frame.
Michelle TAC MT-0
Sarah, Snowball
Rivet Gun Size and Brand JimGolden Ribs, Skins & Rivets 5 11-23-2005 08:48 PM
Factory rivet vs. repair rivet yukionna Ribs, Skins & Rivets 32 09-08-2003 04:41 AM
Rivet gun overlander76 Ribs, Skins & Rivets 1 08-03-2003 06:22 AM
proper rivet gun for AS oldvws Ribs, Skins & Rivets 12 11-23-2002 09:04 PM
