Old 02-28-2014, 04:43 PM   #1
submariner's Avatar
1948 22' Liner
1989 34' Limited
long beach , Mississippi
Rivet Drill Tool
Is there such thing as an alignment tool / attachment for your drill, that keeps the drill bit centered to drill out the skin rivets ?
submariner is offline   Reply With Quote
Old 02-28-2014, 04:48 PM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Yes, there is. They are widely used in the aviation industry and are usually available as surplus. Mighty handy when you have a lot to drill out.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 02-28-2014, 05:09 PM   #3
Central , Mississippi
Vintage Trailer Supply sells one. I mainly use it to START the hole in the rivet then finish with a standard drill bit. It's very fast to run down a row of rivets popping them then come back and drill.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 02-28-2014, 05:15 PM   #4
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Ah, I've always used a spring loaded center punch to start a tiny hole. It has worked every time.
This one is from Amazon, though I picked one up at Harbor Freight.
SE - Center Punch - Automatic, Brass Body, 5in. - Amazon.com
Lynn
WBCCI 21043
Old 02-28-2014, 06:21 PM   #5
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
I've never seen one used in aviation, not saying it does't happen just that I've not seen it. The centre punches did get used by students but never on the job, weirdly I have heard that the centre punch technique actually can make it harder, literally, as it hardens the rivet head, but only at the point it impacts. If you've not drilled many rivets before and you don't plan on drilling a million it sounds like a smart purchase.
truckasaurus is offline   Reply With Quote
Old 02-28-2014, 07:31 PM   #6
submariner's Avatar
1948 22' Liner
1989 34' Limited
i like the tool from VTS. does anybody has an idea, as to where else you can get something like this? i like to see, if there are different designed tools, before i purchase one..
I do have A LOT of rivets to drill though.
Old 02-28-2014, 09:39 PM   #7
1988 Argosy 32
Lomita , California
Try HANSON RIVET Co. www.hansonrivet.com they have about everything you could want.
Wolfe is offline   Reply With Quote
Old 03-01-2014, 07:11 PM   #8
1963 19' Globetrotter
Moline , Illinois
Aircraft Spruce has them , you can order their catalog online. If it is rivet tool they have it. Great service also!
63air is offline   Reply With Quote
Old 03-02-2014, 06:27 AM   #9
submariner's Avatar
1948 22' Liner
1989 34' Limited
thank you guys. I’m getting ready to order bunch of 2024T3 from aircraft spruce. might get the tool from them.
thanks again for the help
Old 03-02-2014, 10:12 AM   #10
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I have a tool like the one from VTS, I have had mine a lot longer than VTS has been in business, works just fine on the few hundred rivets I have drilled out. Where it really comes in handy for me is to not wallow out the holes when using pop rivets. I also have a spring punch for areas where I can't get a clear straight on access with the rivet removal tool.
Aaron
WBCCI #XXXX AIR #2495
Old 03-02-2014, 07:13 PM   #11
Mixter's Avatar
1976 27' Overlander
I have not tried one, but looks like an interesting tool that probably could have helped me in the beginning.
I have now found that the more I do, the better I have become at carefully drilling center. I think after drilling a few hundred, it gets easier to center punch and get that bit dead center. I have done thousands now and almost all of the ones I drill out are very centered.
Also, remember that the rivets swell quite a bit when bucking them back in so I dont think they have to be as perfect as an aircraft. That said, I have been upsizing to 5/32 so even with an off center hole, I'm drilling a new hole in anyway.
However, I do feel confident that I could be re-using the 1/8 hole if I wanted.
Mixter is offline   Reply With Quote
What Kind of Rivet Do I need? Why Olympic rivets? Kyle-King Ribs, Skins & Rivets 10 03-27-2012 09:47 PM
DIY tool for cold rivets? pityocamptes General Repair Forum 3 01-25-2012 05:15 PM
50's Hehr roof vent lifter arm rivet tool vintageair Roof Vents, Skylights & Fans 12 06-29-2011 01:37 PM
Rivet Hole Repair dmcinfo Ribs, Skins & Rivets 9 06-01-2011 08:04 PM
Rivet Tutorial TX_Argosy Ribs, Skins & Rivets 5 05-24-2011 04:19 PM
