Old 07-24-2004, 07:52 PM   #1
Morning Dew's Avatar
Send a message via AIM to Morning Dew
Rivet and Outerskin question
I've got tons of poprivets and a gun, but what kind of rivets/gun will i need for the outerside skin of the coach. are they finishing rivets and how are they applied?? Also I'm having trouble finding large sheets of aluminum. where can i find bulk aluminum and what kind of expense a i looking at for a 4x8 sheet? thanks for the help.
-Brian
Brian Travnicek
31' Sovereign Land Yacht
Pulled by a 2001 Silver Dodge
2500 Truck with Cummins Diesel Power and a 4.10 rear end.
Morning Dew is offline   Reply With Quote
Old 07-24-2004, 08:24 PM   #2
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Brian
For the outer skin you will need olympic rivets - you can get aluminum from www.airpartsinc.com/catalog2004_gif.htm
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 07-24-2004, 11:23 PM   #4
JanP's Avatar
Smile Airstream rivets and skin
You need a finishing bit for your Olympic Rivets to get the nice round head look.
JanP is offline   Reply With Quote
Old 07-25-2004, 12:13 AM   #5
my next question is how thick is the aluminum that was used on the mid-late 70's airstreams? thanks again.
Brian Travnicek
Old 07-25-2004, 12:45 AM   #6
greg176's Avatar
Gabriola Island , British Columbia
Another source for aluminum is www.wicksaircraft.com .Also I do not believe your trailer is made with 2024 .I believe it is either 5052 or 6061.I've tried to get an answer as to which aluminum was used on newer coaches but have had no luck.My 1961 is all 2024-t3 .032 alclad.
greg176 is offline   Reply With Quote
Old 07-25-2004, 12:49 AM   #7
The sections that i'm replacing are behind the rear wheels on both sides. I'm going to be painting everything underneath the belt line. Couldn't I just get the thinnest possibel sheet?
Brian Travnicek
Old 07-25-2004, 12:56 AM   #8
greg176's Avatar
Airstream trailers are a Monocoque body (look it up).Take the time to find out what aluminum they used on your trailer and replace it with same, or you will have problems.
Old 07-25-2004, 07:58 AM   #9
JohnG's Avatar
I would think it correct to use the same type of aluminum since the Monocoque Body design would keep its integerity and the strength would remain the same.
When you buy new aluminum does it have the plasticoat on it or is that something that you have to have applied?
Just adding my 2’ worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 07-25-2004, 08:05 AM   #10
Ken J's Avatar
Durango , Colorado
Images: 14
You can buy pre coated aluminum from Airstream
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 07-28-2004, 09:54 AM   #11
You guys are a wealth of knowledge. I am in search of a airstream and have been peering in for a while, learning and absorbing all that I can. I signed on yesterday so that I can begin to contribute in the areas that I can and just follow, listen and learn where I can't.
Darrell
dbm04F250 is offline   Reply With Quote
Old 07-28-2004, 09:58 AM   #12
Ken J's Avatar
Durango , Colorado
Images: 14
Darrell
Welcome to the forum, we look forward to hearing from you. What model/length/year are you looking for? Perhaps someone on the list will be able to help in your search
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
