Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 07-23-2006, 06:05 PM   #1
Zeppelinium
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
Rivet Alert--trim bands
I got a nasty little surprise yesterday when I started to work on a couple of the banana skins. The lower trim strip covering the top edge of the banana skin, the one from the door forward to the propane tanks, was almost totally disconnected. The bad thing was, it looked tight and ALL the pop rivet heads were in place and looked tight.
However, when I started to drill out the rivets, the two near the door were intact, but the next five in a row were all sheared, then one intact, two sheared, and then the last two were intact. No telling how soon it could have sheared the reaminder and fallen off.
Current 6-word memoir: Vintage Airstreams: Four are not enough.
www.mindseyephoto.com www.airstreamdoctor.com
Old 07-23-2006, 07:27 PM   #2
crowbar68
crowbar68's Avatar
Profile:  1975 27' Overlander
fort wayne , Indiana
popped rivets
it's good timing for this thread. i was inspecting my trim and noticed my rear trim piece is about the same as your front. i have to replace my hot water heater and this will need removed to do so. that is how i noticed it. it did look well attached until a further look! i only thought there were pop rivets until i bought my rig. i'll have to chase some threads and get an education.
do rivets pop often? i9 have already re-popped two access doors and have noticed more loosening ones around different areas. maybe i shoudn't look to close. i'll have to do a full resto! not.
crowbar
crowbar68 is offline   Reply With Quote
Old 08-21-2006, 04:36 AM   #3
gsoter
Profile:  1986 27' Sovereign
Farmville , North Carolina
Hey guys
Pop rivets are what you call mechanical rivets, meaning it has several parts to make them work, body,stem and lockig collor, in time they do work loose. and spin ( aircraft terms " working rivets" ) so it is common to see them spin and shear. just be careful drilling them out, because they want to spin, easiest way to drill head off and then take a punch and knocjk the rest of the rivet thru. be careful when hitting the stem thru, you might have to touch it with the drill again to knock off any burr.there is another side where you dont see, dont want to damage the hole and what is behind it,
gsoter is offline   Reply With Quote
Old 08-21-2006, 05:56 AM   #4
A-Merry-Can
Addicted to Aluminum
A-Merry-Can's Avatar
Profile:  1959 18' "Footer"
1962 19' Globetrotter
1964 24' Tradewind
Woodstock , Georgia
when i put my trim back on my '59 i was planning on using stainless screws, not that i'll be removing them or anything, but it seems like they'd hold better, especially if they hit the "C" channel. my trim may be different that yours, though. it's really thick (1/4"+).
jp
8576 • • • • • • • •
there's always room for one more!
• • www.toolbox-design.com • •
A-Merry-Can is offline   Reply With Quote
Old 08-21-2006, 07:38 AM   #5
Over59
Over59's Avatar
Profile:  1959 26' Overlander
1968 17' Caravel
Images: 37
I think you will find your stainless screws rusting in short order. Marine grade may hold up but I'll defer to others on this.
Let those who can play, let those who cann't rule.
Over59 is offline   Reply With Quote
Old 08-21-2006, 10:47 PM   #6
RVnDixie
RVnDixie's Avatar
Profile:  1975 28' Argosy 28
Homewood , Alabama
Pop-Rivet Monster is killing me!
Hey Y'all,
I have the same problem with alot of my trim bands. Even have some loose in the cabin areas (Wall covering and cabinets etc.). Where and what size are needed to replace? I have the rivet gun but no rivets. Looks like there are different colors too. I would need the white ones for my wall covering, brown for the cabinets an some kind of a copper or antique brass color? (I really don't know what the color is but as close a description as I can get) Any help appreciated!!!
Joseph Tolliver aka "T"
Amy Tolliver
1975 Argosy 28D (work in progress!)
RVnDixie is offline   Reply With Quote
Old 08-22-2006, 06:31 AM   #7
A-Merry-Can
1964 24' Tradewind
Woodstock , Georgia
take a look at Lowes or Home Depot. they have everything you need.
jp
Old 08-22-2006, 04:12 PM   #8
RVnDixie
RVnDixie's Avatar
Homewood , Alabama
Thanks jp. I still don't know the sizes I need for each app...please adv.
Amy Tolliver
Old 08-22-2006, 04:47 PM   #9
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Most of the interior rivets are 1/8in. HDepot has the white ones.
Uwe
Old 08-22-2006, 04:57 PM   #10
Shacksman
Shacksman's Avatar
Profile:  1967 22' Safari
1960 28' Ambassador
Avonton , Ontario
Look where they sell eavtrough in Lowes or Home Depot. They have the colored ones there
Doug
WBCCI #3327 - VAC
73 Argosy
67 Safari
60 Ambassador Int.
Shacksman is offline   Reply With Quote
Old 08-22-2006, 06:05 PM   #11
RVnDixie
RVnDixie's Avatar
Homewood , Alabama
Thanks for the info Uwe & Shacksman...I will go tomorrow and look. Much appreciated!
Amy Tolliver
Old 08-22-2006, 06:13 PM   #12
rebel beck
rebel beck's Avatar
Profile:  1975 31' Sovereign
Oxford , Mississippi
Images: 35
Joseph Ace Hardware here in Oxford has them to. OOps I just noticed yall have moved.
Becky
75 Sovereign (Peppy)
03 Chevy HD (lil Peppy)
Air# 9552
rebel beck is offline   Reply With Quote
Old 08-22-2006, 06:35 PM   #13
RVnDixie
RVnDixie's Avatar
Homewood , Alabama
Hey Becky!
My wife is actually in Homewood right now. I am still in the area (Water Valley). Sorry we did not get to meet before Amy moved over there. I would still like to see your trailer and improvements! I haven't transferred over there yet since there are so many jobs being shuffled around right now, I can't seem to get transferred. Anyway, I am still working on the Argosy as I live in it! Good to hear from you!
Amy Tolliver
Old 08-23-2006, 09:06 PM   #14
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
If you are continually shearing rivets, even a few every trip, it may be time for a new axle or shocks.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
Olympic rivet removal and installation PeterH-79MH Ribs, Skins & Rivets 38 08-13-2008 02:31 PM
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 5 09-24-2006 11:17 AM
rivet tools maznblu Ribs, Skins & Rivets 12 05-31-2006 05:51 PM
blue trim molding larry smith Clearcoat, Exterior Paint & Trim 83 12-07-2003 11:04 AM
Exterior trim ALANSD Airstream Motorhome Forums 1 04-14-2002 07:53 PM
