Old 12-06-2011, 03:31 PM   #1
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
Right Size Drill Bit For Olympic Rivets
Hello everyone.
We are looking on removing our stack window as well as 1 of our VV.
We noticed that we will need olymplic rivets 5/32 to replace them.
After much research we noticed that Vintage Trailers offers the Drill Bit #20 as the option. We also noticed that Andy states that the right size bit is #21.
Any inputs?
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
Old 12-06-2011, 04:03 PM   #2
pgr32e's Avatar
1974 27' Overlander
Sault ste Marie , Ontario
I measured a rivet with a gauge I had and found a number 22 drill bit was the right size. Number 20 is too big.....Phil.
pgr32e is offline   Reply With Quote
Old 12-06-2011, 04:10 PM   #3
Baltimore , Maryland
#20 is what I use. Always a perfect fit for an Olympic or a bucked rivet.
Old 12-06-2011, 04:15 PM   #4
Originally Posted by VeggieBullet View Post
Hello everyone.
Any inputs?
An Olympic rivet is 5/32 which is .15625 inches
#20 is .161
#21 is .159
#22 is .157
The best drill bit size to use is a #21, since a hole will not be perfectly round, unless using a drill press.
Therefore a #22 is too small and a #20 is too large.
Old 12-06-2011, 05:02 PM   #5
alclad's Avatar
1961 16' Bambi
Wilmington , DE
Images: 46
Talking
#20 is .161
#21 is .159
#22 is .157
but that hinges on a perfectly round drill bit, perfectly true drill press, immovable landing table, 100% holding an airstream's drilling target perfectly still
"x" marks the spot. if you have all of the above it may work....if you have close enough you scored and will be proud...
i try to enjoy the imperfect world....
alclad is offline   Reply With Quote
Old 12-06-2011, 05:27 PM   #6
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Hello everyone.
Any inputs?
I used the #20 with no problems
Darkspeed is offline   Reply With Quote
Old 12-06-2011, 06:25 PM   #7
truckasaurus's Avatar
1960 33' Custom
Athens , Georgia
The simple answer is to do what the manufacturer tells the installer to use, the last time I looked for an Olympic is was a #20. I use a #20. Using a drill bit that is the next size up from the fastener isn't always correct; if the fastener engineer specifies a size then that's your best bet; (in my opinion).
truckasaurus is offline   Reply With Quote
Old 12-06-2011, 07:25 PM   #8
pgr32e's Avatar
1974 27' Overlander
Gotta love the forums.....What you do, is take a wee piece of scrap aluminum, your drill and drill a hole or two in each size and decide for yourself. Andy says 21, I find 22 works for me and 20 is too sloppy.....Phil.
Old 12-06-2011, 08:31 PM   #9
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
There is a book for that.
Well, in Army aircraft maintenance we use this manual. If you look at table 7-4 on page 7-14, you'll see that for a 5/32nd rivet a #21 (0.1590) drill bit is specified. Of course an Airstream is not an aircraft, but I use a #21.
Lance
Top is offline   Reply With Quote
Old 12-06-2011, 08:38 PM   #10
Central , Mississippi
I've been lucky I guess...a 5/32 drill makes a hole that is physically impossible to be smaller than 5/32...that's what size I have used for the few dozen olympics and the few hundred buck's I've done...a big plus is the bits are available everywhere!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 12-06-2011, 10:55 PM   #11
Darkspeed's Avatar
1972 31' Sovereign
.002 in an airstream... really?
Old 12-07-2011, 04:10 AM   #12
This is one funny thread. So many experts here, time for me to exit. First axles, then tires, now numbered bit sizes...
Old 12-07-2011, 06:34 AM   #13
1960 33' Custom
Athens , Georgia
I can't believe your giving up Frank.
Old 12-07-2011, 02:59 PM   #14
There are many ways to skin an aluminum cat Truck
Ugly Rivets! Roadrunner Ribs, Skins & Rivets 2 12-04-2011 12:24 PM
Will this part help remove exterior rivets? bennyg Ribs, Skins & Rivets 6 11-17-2011 10:01 AM
Interior Rivets - What size? perryg114 Ribs, Skins & Rivets 16 11-07-2011 10:19 AM
78 argosy interior rivets argosyman General Interior Topics 2 05-17-2011 12:49 PM
