Old 12-22-2011, 11:57 AM   #71
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Originally Posted by danimal327 View Post
I have noticed on my 47 Spartan Manor that all of the rivet heads already have a dimple dead center. I am assuming that whatever shank was used to install the rivets created this dimple. That is going to make it much easier to start the drill bit dead center. Does anyone know if these type of shanks are avalible for a 3X rivet gun?
The rivets you posted a pictured of are AN455AD4-X (#30 drill) which are extremly hard to find anymore and replaced by MS20470AD5-X (#21 drill). Below is AC 43.13 that explains the numbers, Identifiers,alloys, etc
The best drill bits to use are 135 degree split tip in cobalt at around 3000 rpm, more expensive be last 10X longer.
I personally have never used one of those guide tools as they were not available when I started doing aircraft sheet metal way back in 1976
Old 12-22-2011, 12:42 PM   #72
Central , Mississippi
I will add that I used one of those drill guides and found it was very good at STARTING a hole. It is super fast to hit a bunch of rivets and create a very centered shallow hole. I then used a regular bit to finish drilling out the rivet.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 12-22-2011, 01:34 PM   #73
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Many years ago, I found these for sale in solid carbide, double ended (I think at the EAA airshow back when it was still in Rockford, IL.) ... in a SHORT version - perhaps two inches long. They are terrific, if you can find them - because of their short length and hardness, they don't flex or wander at all, and they have lasted for literally decades and have drilled zillions of rivets and rivet holes. Also, because of their sharpness, and when used at highe speeds, they cut fast and clean. Chuck up one of these in a high speed air drill, and yer' ready to go!
Only drawback is that you need a diamond wheel to sharpen them. Then again, I've never needed to sharpen them!
AirsDream is offline   Reply With Quote
Old 12-23-2011, 09:26 AM   #74
Wimberley , Texas
Just a quick question. I went to the Airparts web site https://www.airpartsinc.com/shopexd.asp?id=189 . They show a ms20470ad4-x. Would that not be an 1/8th inch rivet/ #30 bit? I want to make sure I don't end up buying a 1000 incorect rivets.
Dan
danimal327 is offline   Reply With Quote
Old 12-23-2011, 02:07 PM   #75
Aerowood's Avatar
Arvada , Colorado
Let me explain one other thing. AN455AD4-X rivets have a manufactured head of 5/16 diameter. In order to replace then with a MS20470AD rivet you will have to use a 5/32 rivet which has a manufactured head diameter of 5/16.
So if you want the diameter of the replacment rivets to match closely to the exisiting AN455AD4-X rivets, you will have to order MS20470AD5-X rivets.
Also check that Airparts rivets do not have as I call the, "Paragraph on the head", which is a bunch of lettering. I order all of my rivets from here
Genuine Aircraft Hardware Co.
Old 12-27-2011, 01:44 PM   #76
Wimberley , Texas
Thanks Aerowood!
You a truley a rivet master!
Ugly Rivets! Roadrunner Ribs, Skins & Rivets 2 12-04-2011 11:24 AM
Will this part help remove exterior rivets? bennyg Ribs, Skins & Rivets 6 11-17-2011 09:01 AM
Interior Rivets - What size? perryg114 Ribs, Skins & Rivets 16 11-07-2011 09:19 AM
78 argosy interior rivets argosyman General Interior Topics 2 05-17-2011 11:49 AM
