Old 12-12-2011, 01:57 PM   #29
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Well the aluminum is most often .032 thick so if joining two sheets you would need one with a minimum of .064 grip
For sheet work the first on list looks good
For going into ribs through a sheet maybe the second or third
Darkspeed is offline   Reply With Quote
Old 12-12-2011, 02:49 PM   #30
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
can these be shaved?
Hi Todd.
Can these be shaved? By looking at the pics of the first one they don't really look like the Olympic.
These will be used for the VistaView and Stack windows.
97447A032
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
Old 12-12-2011, 03:34 PM   #31
Originally Posted by VeggieBullet View Post
Hi Todd.
All Olympic rivets must be shaved, to look likr the buck rivets.
Old 12-12-2011, 04:10 PM   #32
1973 31' Sovereign
2007 20' Safari SE
so blind rivets...
are the same than the olympic rivets?
We are looking at the Domed Aluminum
McMaster-Carr
2 chronicles 7:14
Old 12-12-2011, 05:18 PM   #33
Darkspeed's Avatar
1972 31' Sovereign
McMaster-Carr
The mcmaster rivets will not look like an airstream rivet - they will look like a pop rivet.
To look like an airstream rivet you need Olympic rivets - when you pop them the stem sticks out so you can trim it down flush so it looks like a solid rivet.
Old 12-12-2011, 05:22 PM   #34
Darkspeed's Avatar
1972 31' Sovereign
First is mcmaster
Second is olympic
When the Mcmaster pops the stem is broken off in the head so there will be a hole in the middle and it will not look like a solid rivet
ID:	146968   Click image for larger version
Old 12-12-2011, 05:23 PM   #35
Darkspeed's Avatar
1972 31' Sovereign
Here is a shot of the closed end rivet from mcmaster
Old 12-12-2011, 06:59 PM   #36
2008 27' Classic FB
Plymouth , Massachusetts
The reason a slightly oversized drill bit is used on rivets is so that the rivet will slip easily into the hole. Using a 5/32 bit would not be an issue doing 4 or 5 rivets but for production work it would be highly unproductive not to drill a slightly oversized hole. In airplane construction numbered drill bits are always used...#30 for 1/8 and # 20 for 5/32 etc. The 5/32 size is only the pre-pulled diameter, not the final pulled diameter, when a 5/32 rivet is pulled it will fill the #20 drill bit hole.
Don...
2008 27FB Classic
My Airplane Construction Website:
http://www.donsbushcaddy.com
NTRPRZ is offline   Reply With Quote
Old 12-12-2011, 07:59 PM   #37
Not when you use an Olypic rivet, since the rivet shank does not swell, but instead the back side splits into thirds which does nothing for the hole.
Old 12-13-2011, 10:38 AM   #38
1973 31' Sovereign
2007 20' Safari SE
this is learning process is getting more and more interesting every day.
Now: What is the best source for buying Olympic Rivets? Don't really want to pay over $20 for just 100 of them. But if there is no other choice...
2 chronicles 7:14
Old 12-18-2011, 08:21 AM   #39
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I just removed some solid rivets by chiseling the head off which was easier than I thought it'd be. Can you use this same removal method for Olympics?
desertair27 is offline   Reply With Quote
Old 12-18-2011, 08:26 AM   #40
Most dealers charge at least 60 cents per olympic rivet.
Bag prices from them are always cheaper.
Old 12-18-2011, 08:45 AM   #41
The Airstream factory specs a #21 drill bit for the Olympics.
The Official Airstream Rivet Kit contains everything you need to get started. It contains a Marson Klick-Turn Swivel Head Rivet tool with 4 nose pieces (3/16”, 5/32”, 1/8”, 3/32”) and an assortment of rivets including 25 each of the following: Olympic Rivets (exterior repair rivet), 1/4” head diameter rivet with 3/8” length and with 1/2” length for interior rivet replacements, and underbelly rivets with two different head sizes. Also includes drill bits, #10, #21 and #30.
Old 12-18-2011, 01:41 PM   #42
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
While I hear of people doing this all the time it does have a tendency to stretch the aluminum, Drilling is still the best option.
Ugly Rivets! Roadrunner Ribs, Skins & Rivets 2 12-04-2011 11:24 AM
Will this part help remove exterior rivets? bennyg Ribs, Skins & Rivets 6 11-17-2011 09:01 AM
Interior Rivets - What size? perryg114 Ribs, Skins & Rivets 16 11-07-2011 09:19 AM
78 argosy interior rivets argosyman General Interior Topics 2 05-17-2011 11:49 AM
