Old 05-01-2011, 06:30 PM   #1
1968 26' Overlander
West Richland , Washington
Rib repair or replace?
I finally have my interior skins off and insulation removed and noticed a broken rib. This was a rib at an interior wall and looks like a sever bump pushed a vertical support up and cracked it. Currently plan on putting a splice on it for a repair and I'm hoping I get some support that this is an acceptable fix. What do you think?
Also found a couple of fubars when it was built. One of the pics is my bathroom vent hole(s). Apparently drilled it in the wrong location oops- patched it and tried again. The third pic is my vista view window next to the door. If you look closely, you can see why I couldn't raise the visor to full open position. When they put the awning on, they used screws that were too long to install the metal rib up on the roof. The screws stop the visor.
Sure hope these pics come thru ok. its my first attempt.
ID:	128830   Click image for larger version
JIMandPJ is offline   Reply With Quote
Old 05-01-2011, 07:03 PM   #2
r carl's Avatar
Lin , Ne
I would replace it.
Old 05-01-2011, 07:07 PM   #3
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
JimandPJ,
Repairing the rib (former) won't be an issue. If you can find a new piece of former that could be spliced in. It would be easier and just as good to repair it with some similar thickness aluminum.
That third picture has to make you chuckle a little.
Lance
Top is offline   Reply With Quote
Old 05-01-2011, 07:21 PM   #4
pgr32e's Avatar
1974 27' Overlander
Sault ste Marie , Ontario
The rib is repairable, though the hole makes it a bit of a challenge. By any chance do those wires terminate close by so you could do the repair and then re run them? Love the screws, proves Murphy is everywhere.......Phil.
pgr32e is offline   Reply With Quote
Old 05-01-2011, 09:13 PM   #5
1968 26' Overlander
The wiring is existing and is going to come out. Its 110V and is aluminum instead of copper. I think I can re-route the wiring around this hole.
Old 05-02-2011, 02:31 AM   #6
vinstream's Avatar
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
I would do what they call "sister" a new 12" or so "C" channel back to back so that the two "C" channels make a "I" that way you are able to still use the existing Rib member! I among a very small few who even know how to bend the "C" channel properly let alone the many hours to de-skin and re-skin so that it looks correct! If you need a 12" section I send you a section FREE! Good luck!
Todd Ingbretsen
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Dash Repair shepherd57 Argosy Motorhomes 2 06-22-2013 06:48 AM
Newbie needs soft floor repair advice lbdesign Repairing/Replacing Floor &/or Frame 20 09-10-2012 11:32 PM
Hard To Replace Sony In '06 Bambi? jambie Audio, Video & TV 19 08-24-2012 12:18 PM
Lots of Rib questions... NicheVintage Ribs, Skins & Rivets 12 07-10-2012 03:22 PM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 06:20 AM
