Old 09-23-2014, 12:02 PM   #15
Originally Posted by putback View Post
Normal, on the ones I've done, all pre '68, the front corner .032 channel type ribs are not connected to the floor. What has really shocked me is how few of the original extruded aluminum body bows [ribs] that are not connected to the C channel or floor. The worst example I've seen is my '62 ambassador. Only 2 full length bows connected to the floor, at the front and rear end caps. Every other rib stops at the top center and not attached to the floor, none full length and no apparent reason why not. Even the ones on either side of the entry door not anchored. I extended and anchored all.
That is absolutely normal.
Old 09-23-2014, 12:03 PM   #16
Originally Posted by pinkflamingoes View Post
What's Andy's user name?
Which Andy?
Old 09-23-2014, 12:40 PM   #17
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I'm no structural engineer so I cannot give an expert opinion about any problems the "short ribs" might cause, but my intuition suggests this could be a problem. If it this occurred on my rebuild, I would make sure all the ribs extended and were secured to the C channel. It would not be a big deal to do this when the trailer is in a deconstructed condition.
Bob Martel
WBCCI# 5766
Old 09-23-2014, 01:14 PM   #18
pinkflamingoes's Avatar
1967 24' Tradewind
Alameda , California
Images: 38
Send a message via AIM to pinkflamingoes Send a message via Yahoo to pinkflamingoes
That's what we were thinking. Most of the ribs are U channel so since w're getting ready to fab or buy some, we think we'll just extend what is there. He says it's easy and can't hurt not to.
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 09-23-2014, 01:17 PM   #19
1967 24' Tradewind
Images: 38
Then I start to worry about lengthening and connecting the ribs making things to stiff. I always find something to worry about.
~ Hurley
ingrid
Old 09-23-2014, 01:21 PM   #20
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
The way the shell gets its strength, mostly from the outer skin, the short ribs will make little to no difference in rigidity...
I would not worry about them if it was my trailer.
Old 09-23-2014, 01:32 PM   #21
1979 23' Safari
Wayland , New York
Looking at the curvature on the bottom picture; I'm guessing that that is the lower rear street side corner of the trailer and the rib's only go from above the bottom of that exterior panel to somewhere still below the top of the bottom of that exterior panel; if that makes sense(ie they're pretty short, probably just z shaped as well) those are normal, they can't run rib's all the way from the floor to the overhead so these help provide some basic rigidity to the exterior skin in that area.
Old 09-23-2014, 02:06 PM   #22
1967 26' Overlander
Bugtussel , Oklahoma
I've got some short ribs on my 67 Overlander. I don't know why it was built that way but I'm not going to spend time "fixing" it.
1967 Overlander International 26ft
2006 Porsche Cayenne Turbo S 520hp 530ft-lbs torque 7700lb towing capacity
mikextr is offline   Reply With Quote
Old 09-23-2014, 04:19 PM   #23
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I think when the inner skins are attached to the bows you end up with a pretty strong structure. I believe I have read where some rebuilders do extend the bows to the C channel making even a stronger structure.
Aerowood seems like an aircraft structure expert and is another source for information concerning the short bow lengths and their effect.
David
Old 09-23-2014, 04:23 PM   #24
Those "ribs" are correctly called "main bows".
Old 09-23-2014, 07:21 PM   #25
1967 24' Tradewind
Images: 38
I can't imagine so many Airstreams would have them if they were a problem, since I've never seen this issue come up, I'm guessing it's not something to stress over. Since my husband is doing the work, I'll leave it up to him. Will keep you posted.
~ Hurley
ingrid
Old 11-10-2014, 06:52 PM   #26
Brasslens's Avatar
1957 22' Flying Cloud
Mississauga , Ontario
I just opened up the front end of my 1957 22' Caravanner and have noticed that the ribs do not extend all the way to the bottom. It looks like it was made like that originally. I'm planning on extending them to the bottom C channel when I get to that point.
Brasslens is offline   Reply With Quote
Old 11-11-2014, 07:43 AM   #27
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I attached all of my ribs to the lower C channel, very little work involved.
Old 09-09-2016, 12:58 PM   #28
Goliad , Texas
AW, where do you get the channel to construct the ribs. I have a '65 that I am redoing and am looking for quite a few feet of this material. I will use for the horizontal ribs where I will beef up where new shelving will be installed and use for wall studs for new walls.
I believe it is .032 channel and definitely measures 3/4"x11/2"x3/4". I do not have the tools to bend it and being I need so much, I have decided just to buy it if I can find it.
The Frommes
Goliad, Texas
The Birth Place of S. Texas Ranching
WBCCI #6256
eartick is offline   Reply With Quote
Prime Rib / Magic Chef doorgunner Stella's Kitchen 9 01-13-2009 06:45 PM
63 Safari Roof rib replacement airstream4 Ribs, Skins & Rivets 9 04-14-2008 10:04 AM
I Bow Before You (with plate in hand) Her-Highness Shari aka "Rib Queen" MileHigh Off Topic Forum 1 10-16-2004 12:47 PM
The first day. Broken Rib? Charming Wino 1974 Overlander 12 03-07-2004 06:11 PM
bent/cracked rib? Jabba Ribs, Skins & Rivets 1 10-27-2002 06:04 AM
