Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 08-27-2004, 01:07 PM   #71
joecj76
Profile:
Talking
onest you been leared english good, hain't nobody can change that!...
Does that help with YUR confusion? LOL. It just kills me to think what people due to the English language.
any help would be....ah.....most helpful!
joecj76 is offline   Reply With Quote
Old 08-27-2004, 01:36 PM   #72
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
I thought this site was to help Airstream owners, with their Airstream concerns and/or their Airstream problems, as well as to share Airstream experiences and Airstream knowledge.
Gosh, if we have to toss in being gramatically correct, I am afraid many of us would no longer post.
Most often, everyone knows what you mean, without have to say "you know what I mean," even though at times, we bend the English language.
However, bending the English language is far more forgiveable than bending an Airstream, and that's the real reason for this site, "AND" it's success.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Inland RV Center, In is online now   Reply With Quote
Old 08-27-2004, 02:02 PM   #73
dscluchfc
dscluchfc's Avatar
Profile:  1984 31' Excella
Abernathy , Texas
Ok..I give up...UR right..
dscluchfc is offline   Reply With Quote
Old 08-27-2004, 02:47 PM   #74
markdoane
Profile:  , Minnesota
Images: 59
?? Wasn't UR a city in ancient Mesopotamia? Don't see the conxshun. . . .
Non-contributing deadbeat.
Old 08-27-2004, 02:55 PM   #75
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
As another example, with a ball park 750 pounds tongue weight, a large car would use a 1000 pound hitch, a 1/2 ton truck a 750 hitch, and a 3/4 to 1 ton truck a 550 pound hitch.
Andy,
I an not sure what you are describing in the above quote:
Are you referring to the hitch weight rating of the bars?
OR
Is this the total load that is being transferred forward to the center of the vehicle?
OR
Is this the tongue weight of the trailer?
I am so confused..........
TIA
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 08-27-2004, 05:34 PM   #76
Commercial Vendor
Brett.
The numbers I listed are the "bar" ratings.
Inlandrv.com
800-8777311
Old 08-27-2004, 08:59 PM   #77
Silver Bullet
Silver Bullet's Avatar
Profile:
Andy, Noting today's tow vehicle.....
The 1000 lb bars are pretty obsolite, unless you pull with a 74 Chrysler "Town and Country " station wagon.
Oscar
Silver Bullet is offline   Reply With Quote
Old 08-29-2004, 11:07 AM   #78
alvinator
WBCCI 17745
alvinator's Avatar
Profile:  2006 34' Classic
Lock Haven , Pennsylvania
What Airstream and Reese have to say
I have a 2005 28 Classic being pulled by a 2004 Dodge 2500 Cummins 4WD Auto. I have the Reese HP Dual Cam setup with 1200 lb bars. After reading all these posts regarding the proper spring bar weight, I was concerned enough to contact both Airstream and Reese regarding the matter as follows:
Message: I have a 2005 Airstream 28
2004 Dodge 3/4 ton Cummins
Diesel Pickup. Airstream
lists the unloaded trailer
weight weight at 6800 lbs and
the tongue weight at around 800 lbs.
I use the Dual cam straight
line hi performance setup. Do
I need 800lb spring bars or
1200 lb spring bars?
Thank you.
Airstream's answer was:
Here is a site that will help you out with your questions. If you have any more questions please e-mail. http://www.reeseprod.com/
_______________________
Thank you,
Joe Williams
Airstream
Customer Service Manager
Now here is Reese Products one word answer to me. 1200#
Comments?
alvinator
alvinator is offline   Reply With Quote
Old 08-29-2004, 11:36 AM   #79
dano
Profile:
grossly overhitched?
I was following this thread and have a question if you don't mind. I have a 1987 25' Sovreign with a V5 Drawtight receiver hitch and 1000 lb. spring bars. The tow vehicle 2003 Chevy Avalanche 3.73 rear ratio. In your opinion am I over hitched for this trailer? Thanks!
dano is offline   Reply With Quote
Old 08-29-2004, 12:36 PM   #80
Commercial Vendor
alvinator.
There are several issues that must be considered.
First of all, you must provide a "soft" ride for an Airstream trailer. If not, then you usually damage the front end.
That being the case, the "bars" must have some flex.
Secondly, at the same time, adequate weight transfer must take place.
Third, if the above are the conditions, then what is the weight and balance on your rig?.
No one, anyone can make a flat statement that any size bars can be used, without first knowing the trailer, the tow vehicle, and the tow vehicle rear spring rate.
Then and only then, can you make a proper determination.
Lastly, Reese has never made an insurance settlement for loss of control accidents.
I have made several hundreds of them.
Inlandrv.com
800-8777311
Old 08-29-2004, 01:04 PM   #81
alvinator
WBCCI 17745
alvinator's Avatar
alvinator.
In my prior post, I detailed the trailer specs and the the tow vehicle specs.
What weight spring bars should I be using?
alvinator
Old 08-30-2004, 03:29 AM   #82
qqq
qqq's Avatar
Profile:
I still would like to know if this crash was caused by human error!
Ron
qqq is offline   Reply With Quote
Old 08-30-2004, 09:39 AM   #83
Commercial Vendor
alvinator.
I answered your question in detail yesterday, however, when I went to post it, AOL said "goodbye."
Therefore, it was lost.
I will try it again, today or tomorrow.
It took about 45 minutes, just to type it.
Inlandrv.com
800-8777311
Old 08-30-2004, 09:44 AM   #84
Commercial Vendor
qqq.
Human error almost always enters the picture, especially when someone is improperly rigged.
Correcting an appreciable sway, by feel, cannot be done. There is the problem, in itself.
A pilot cannot fly an aircraft by the seat of their pants, and a good sway, cannot be eliminated by the seat of the drivers pants, either.
By actual tests, what you physically think and feel you should do, in fact, is the opposite thing that should have been done.
More later.
Inlandrv.com
800-8777311
Want 28-31 ft. Airstream newmanjk For Sale & Wanted 0 08-04-2004 10:02 PM
2005/2006 International Rallies Over59 WBCCI Rallies 21 06-24-2004 11:55 AM
Where do you shop for Airstream stuff? cwbastian The Vendor's Forum 4 05-16-2004 02:30 PM
Selling 1987 Airstream Model 345 Guy For Sale & Wanted 0 03-07-2004 09:21 PM
airstream! airstream! airstream! 83Excella Our Community 0 03-23-2002 11:37 PM
test
