Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 08-26-2004, 02:29 PM   #57
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
markdoane.
And an excellent one it is.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Inland RV Center, In is online now   Reply With Quote
Old 08-26-2004, 02:48 PM   #58
62 Overlander
62 Overlander's Avatar
Profile:  2005 25' International CCD
1954 25' Cruiser
Paradise , Texas
Originally Posted by Diesel Pusher
My truck weighs around 6,600 pounds total. The front end is obviously heavier than the back end. When the truck is empty, the back end sits up much higher than the front. When the trailer is loaded onto the ball, the truck sits about level. The bottom leaf spring is a little higher than level and not touching the next one above it. I have hauled bricks, sand etc. in it and have seen where the leaf springs have touched, but I have never overloaded it.
What kind of set up would you recommend for me and where do I purchase it?
Also, is it something I can install myself, or do I need to have it professionally done. Thank you for your comments.
Rob.
Here's a source
http://www.campingworld.com/browse/p...=SRCH&tcode=37
Paul & Annie
"No matter where you go, there you are..."
WBCCI #7162
Charter Member - Heart of Texas Camping Unit
AIR #1565
62 Overlander is offline   Reply With Quote
Old 08-26-2004, 04:08 PM   #59
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Thanks Andy. I have a '96 Impala SS that has basic cargo coils and I have an '04 3/4 ton Suburban which has the same leaf config as the 2500 (NON HD) series trucks (no overload leaf from what I can tell). The trailer is an '04 25' Safari with a listed hitch weight of 750lbs. I have weighed the tongue and with just the basics, LP gas (2 30#tanks, full), 2 batteries and spare tire. With this, it weighs 670lbs. I figure if I add stuff to the storage areas (approx 130lbs, which could happen) that are north of the axles, I might reasonably be able to get it to 800lbs, maybe even 825-850 depending on what I haul.
So using the 1000# bars on the Suburban with the Safari sounds pretty close, however when I towed the 19' Bambi with the Impala SS w/ 1000lb bars, it sounds to me that I might have been overhitched as the Bambi had a hitch weight of 460lbs.
Any comments or suggestions would be greatly appreciated.
Old 08-26-2004, 06:16 PM   #60
Commercial Vendor
Silvertwinkie.
ou are at the opposite end of being close.
With the overload springs you have on th Suburban, you should use a 550 pound hitch, and no more.
Remember the basics.
Minimum 1 inch bend in the bars, 2 inches is even better.
I don't think you can do that with a 1000 pound bar, unless you raise the Suburban's rear end higher than level.
But, do as you wish, then do the truck scale and then the ride in the back.
That, will answer your questions.
The idea is not to be just sort of OK, but to be as well rigged as you can.
Your not there with 1000 pound bars.
As another example, with a ball park 750 pounds tongue weight, a large car would use a 1000 pound hitch, a 1/2 ton truck a 750 hitch, and a 3/4 to 1 ton truck a 550 pound hitch.
The truck scales, the bend in the bars, the handling of the tow vehicle, and the ride in the back of the trailer, as well as many many research test, "all" support that formula.
For those that may doubt, do the research, but do it all.
Your ultimate findings will match the above, simple formula.
And that's it folks, that simple.
Inlandrv.com
800-8777311
Old 08-26-2004, 06:47 PM   #61
Silver Bullet
Silver Bullet's Avatar
Profile:
Where on a Reese DC bar is the load range stamped, ie 550, 750, 1000 lb?
Oscar
Silver Bullet is offline   Reply With Quote
Old 08-26-2004, 07:07 PM   #62
Commercial Vendor
Silver Bullet.
The bars are not stamped.
But you can measure the width of the bar as it enters the trunnion.
A 1 inch bar is 450 pounds, a 1 1/8 inch bar is 650 pounds and a 1 1/4 inch bar is 900 pounds.
When you add the straight line "dual cam" sway control to it, you add another 100 pounds.
Been that way since 1966, that I know of.
The ball mounts accept all three sizes, as the trunnion ears are the same, but the square holes is one of three different sizes.
Inlandrv.com
800-8777311
Old 08-26-2004, 09:16 PM   #63
Silvertwinkie
Aluminut
Thanks Andy for the tips and info. Much appreciated!
Old 08-26-2004, 10:57 PM   #64
swebster
RivetAddict
swebster's Avatar
Profile:  Louisville , Kentucky
Phew, I'm so glad I bought a motorhome.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
View My ThisOldRV.com Personal Page
ThisOldRV.com
swebster is offline   Reply With Quote
Old 08-27-2004, 07:05 AM   #65
markdoane
Profile:  , Minnesota
Images: 59
Boy, I would love to be to have those whirring transmission sounds, leaky carburators, and overheating. And that great 454 gas engine!
Non-contributing deadbeat.
Old 08-27-2004, 07:41 AM   #66
swebster
RivetAddict
swebster's Avatar
Talking
Don,
It's easy. Put some go-go juice in one end and hit the pedal on the right. If you hear loud noises....just turn up the tunes!
Steven Webster
AIR 1760
ThisOldRV.com
Old 08-27-2004, 08:49 AM   #67
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 162
Thank you, INLAND RV
ANdy:
Thanks for taking time to discuss this subject.
I eagerly await BOTH of your upcoming articles.
Again, thanks for sharing your knowledge and opinion.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 08-27-2004, 09:42 AM   #68
Commercial Vendor
swebster.
Yeah, motorhomes are OK, but you can't float them down the river, because they don't have any wheels near the center for ballast.................
Inlandrv.com
800-8777311
Old 08-27-2004, 11:29 AM   #69
markdoane
Images: 59
swebster.
Yeah, and those heavy iron motors make them bow heavy, so its tough to get them up on plane!
Old 08-27-2004, 12:35 PM   #70
dscluchfc
dscluchfc's Avatar
Profile:  1984 31' Excella
Abernathy , Texas
OK...I am curious.
How much money to purchase an extra set of Reese Bars?
Or, how much money to trade a set of 1000 bars for some 750's or 550's?
Anyone got a web link?
I am apparently over hitched with a 2500HD 4x4 Crew Cab Duramax-Allison.
However, I was ok with them on the lighter sprung Yukon I was towing with.
dscluchfc is offline   Reply With Quote
Want 28-31 ft. Airstream newmanjk For Sale & Wanted 0 08-04-2004 10:02 PM
2005/2006 International Rallies Over59 WBCCI Rallies 21 06-24-2004 11:55 AM
Where do you shop for Airstream stuff? cwbastian The Vendor's Forum 4 05-16-2004 02:30 PM
Selling 1987 Airstream Model 345 Guy For Sale & Wanted 0 03-07-2004 09:21 PM
airstream! airstream! airstream! 83Excella Our Community 0 03-23-2002 11:37 PM
test
