Old 09-24-2015, 06:18 AM   #1
1963 24' Tradewind
Billings , Montana
Replacing Ribs
What alloy are the ribs made from? The same as the exterior? In my case, from 1963, the 2023T3 alcad is the exterior. I have two dents that bashed two lower horizontal ribs pretty good. I'd like to make new ribs, and cheaper is better (it does not need to be shiny). BUT, I don't want different alloys to react.
www.airstreampadawan.com
micaso is offline   Reply With Quote
Old 09-24-2015, 06:41 AM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
The different alloys won't react. 5052 will be a common replacement...any aluminum which will take the bending from a break. The best and fastest thing to do is go to your local sheet metal company...heating and cooling duct makers....and have them bend up a couple 2 inch channels.....or what ever size you need. Overall, it's not a big deal..don't make it one. Your outer skin panel and leak control is now your area of concern.
Old 09-24-2015, 07:02 AM   #3
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
would 2" channel be better than z strips? I'm guessing it would be stronger, but you just can't buck rivet a square tube, and if you used "U" channel, you cant attach on the inside. Be aware, you'll need to use Olympic rivets with your ribs.
robwok is offline   Reply With Quote
Old 09-24-2015, 07:08 AM   #4
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
CRL Satin Anodized ''Z'' Bar Aluminum Channel - 12 ft Long - Rakuten.com
You can do a search for aluminum z bar extrusion. I also know that I got some shorter curved pieces from Out of Doors Mart in North Carolina. You may be able to get a rib piece from Inland RV in California. The other option is possibly to bend it back out. If you get access to the area by removing the skins, get a heavy steel channel or I beam. then, block it at both ends, then slowly draw the dent to the channel with a large "C" clamp.
Old 09-24-2015, 07:08 AM   #5
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
You can buck a rivet inside a U-shaped rib with an offset bucking bar. It's done all the time in aircraft work. Check Aircraft Spruce and Specialty's website for the bar.
Old 09-24-2015, 08:28 AM   #6
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Why are you even considering bucking a repair? All my Vintage Airstreams have C channel ribs....what is meant by you can't attach to the inside? I think your have the channel mentally placed sideways.
Old 09-24-2015, 08:31 AM   #7
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Ditto.
Brevi tempore!
Old 09-25-2015, 02:41 PM   #8
1963 24' Tradewind
Billings , Montana
Thank you all! I hadn't thought to go to a heating/cooling store and was trying to figure out how to the bending myself. Breaks are expensive. WAY easier to ask the people who installed my furnace recently--I'm even a semi-recent customer.
Old 09-25-2015, 03:14 PM   #9
1979 23' Safari
Wayland , New York
Just to clarify. These are horizontal ribs between the main vertical ribs right?
Old 09-26-2015, 09:02 AM   #10
1963 24' Tradewind
Billings , Montana
Yep, just the horizontal ones. The vertical ribs are, mercifully, in good condition.
Old 09-05-2018, 10:20 AM   #11
1967 28' Ambassador
Charlevoix , Michigan
anyone have any suggestions on the vertical ribs? how to bend a c channel like that
rubysails is offline   Reply With Quote
Old 09-11-2018, 07:52 AM   #12
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
How long of a piece do you need?
Old 09-12-2018, 08:18 AM   #13
islandtrader's Avatar
1956 22' Caravanner
Don Pedro Island , Florida
Go to ebay and you will find any shape and size that you can imagine .
My Rebuild page : 1956 Caravanner
https://www.airforums.com/forums/f11...ml#post1921527
islandtrader is offline   Reply With Quote
Old 09-12-2018, 09:34 AM   #14
Aerowood's Avatar
Arvada , Colorado
The vertical ribs have a radius bend to them. If the a small section is needed then they can be fabricated from three pieces. Longer pieces can also be fabricated or a shop with some the correct roller dies on some specialized equipment can help you out.
Smoked ribs Hawkeye5 Stella's Kitchen 10 05-18-2008 10:29 PM
How wide are the ribs in a classic motorhome guy99 Classic Motorhomes 2 02-27-2006 01:24 PM
No Ribs in front & rear??? BornToRock Ribs, Skins & Rivets 0 08-28-2005 09:20 AM
oh my aching ribs desi arnaz Ribs, Skins & Rivets 7 07-10-2005 11:27 AM
Replacement ribs crgintx Ribs, Skins & Rivets 5 01-16-2004 12:27 PM
