Old 03-04-2009, 04:36 PM   #1
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
replacing olympics with bucks
My interior is out and my exterior has some leaking olympic rivets. I'll replace all the olympics and a few bucks with buck rivets. I've read here that 1/8 bucks expand to completly fill their hole. The question I have is will the 1/8 bucks seal the hole left by the removed 5/32 olympics, or do I need to use 5/32 bucks?
putback is offline   Reply With Quote
Old 03-04-2009, 04:57 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
You will need 5/32" solid ("bucks") rivets.
Shari
Old 03-04-2009, 07:36 PM   #3
Images: 59
5/32" Universal buck rivets have a head diameter that is the same as the original Brazier head rivets. If you use 1/8" Universal rivets the head will be noticeably smaller. Better to use 5/32" for that reason.
Old 03-04-2009, 08:50 PM   #4
D&D
1971 29' Ambassador
Sioux Falls , South Dakota
Dumb question I know but if I don't ask I won't know so here it is---- are bucking rivets also called solid rivets? Can you buy them at any hardware store or where? My interior is out of my AS and now is the time to do it right! Thanks! Dale
D&D is offline   Reply With Quote
Old 03-05-2009, 03:52 AM   #5
Images: 59
Bucked rivets are solid rivets that have been "bucked" with a rivet set and bucking bar. You would need a rivet gun and bucking bar.
Check Aircraft Spruce or Airparts Inc for sheet, tools, rivets and other stuff.
Old 03-05-2009, 07:16 AM   #6
InsideOut's Avatar
1956 22' Safari
Images: 108
Originally Posted by D&D View Post
<snip> ...are bucking rivets also called solid rivets? Can you buy them at any hardware store or where?
Check out this thread for an explanation on the different kinds of rivets. Start at Post #14.
Shari
Old 03-05-2009, 04:43 PM   #7
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
Thanks, read the referred post and more. Unless someone warns me off I'll use 5/32 Universal buck rivets for all replacements. Shure going to make the job easier.
3rd battery for less than 10 bucks john hd Batteries, Univolts, Converters & Inverters 18 09-17-2007 07:34 PM
How possible is a 2008 Olympics Rally in Beijing? roamingwesty Travel Beyond US/Canada 11 01-31-2007 09:37 PM
two cyclo polishers nine bucks john hd Cleaning, Stripping & Polishing 14 12-05-2005 06:16 PM
50 Bucks In The Wind? Perry Commercial Listings 10 07-06-2004 11:48 AM
