Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 09-29-2006, 10:33 AM   #1
rama777
Profile:  1974 31' Sovereign
jemison , Alabama
replacing insulation?
I have 74 31' AS that I am restoring. Is it necessary to replace the insulation. I haven't determined yet if there is water damaga. If there isn't, is it still a good idea to replace it. Also, how do I remove the rivets and when I put the skins back on, I am assuming I should use new rivets and so what will I need to punch those new rivets in? Thanks!
rama777 is offline   Reply With Quote
Old 09-29-2006, 10:48 AM   #2
LI Pets
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
Are you asking about the floor or walls?
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
LI Pets is online now   Reply With Quote
Old 09-29-2006, 07:35 PM   #3
rama777
jemison , Alabama
the walls
Old 10-13-2006, 02:39 PM   #4
BB 55 Bubble
BB 55 Bubble's Avatar
Profile:  1955 16' Bubble
Bend , Oregon
Talking Insulation
Check out my thread on the subject there is some good info http://www.airforums.com/forum...ion-24037.html. The material I plan on using is
Reflectix
Technical info is:
[b]Temperature Range: -60 degrees to +180 degrees F
Nominal Thickness: 5/16 inch (.312)
Weight: 1.25 oz./sq. ft.
Flame Spread Index (ASTM E 84): 20
Smoke Developed Index (ASTM E 84): 30
Fire Rating: Class A/Class 1
Linear Shrinkage: None
Reflectance (IR): 97%
Water Vapor Transmission (ASTM E 96): 0.02
Puncture Resistance: 60 lb./in.
Mold and Mildew: No Growth
Emittance: 0.3
Tensile Strength: 3.7 N/mm
Pliability: No Cracking
Hot Surface Performance: Passed
R value : 16.8
It is called:
Double Bubble
Foil Both Sides
At the Home Depot:
16 In. x 25 Ft. Reflective Insulation
Model ST16025
Price: $14.95/ea
There is a fine line between firefighter and Pyro. I am who ever is having the most fun!/
BB 55 Bubble is offline   Reply With Quote
Old 10-13-2006, 03:00 PM   #5
LI Pets
Silver Mist
LI Pets's Avatar
Check this out
http://www.airforums.com/forums/f36/insulation-between-floor-belly-pan-what-use-25494-2.html?highlight=prodex
This stuff looks good http://www.insulation4less.com/highr_FfmF.asp
  • Is waterproof and non-absorbent.
  • Provides Class A/Class 1 fire rated protection.
  • Provides 19 DB Soundproofing.
  • Convenient flange tabs on sides.
  • Does not mildew or promote fungus growth.
  • Does not provide nesting for birds, rodents or insects.
  • Is safe for workers to use as there are no fibers to breath or cause skin irritation.
  • Has more insulation value than 6 inches of common mass insulation products.
  • Can be stapled, nailed, glued or sewn.
  • Easy to cut
  • Reflects 97% Radiant Heat
  • R-14.5
$70 for a 4x25 piece.
I started using it last week it is reall y nice it forms to shape.
If you use it in wall just cut 1/2" wide stripes for air spacers.
I just used it to insulate my water tanks, GREAT< GREAT.
http://www.airforums.com/forums/f36/insulation-between-floor-belly-pan-what-use-25494.html?highlight=lipets
WBCCI
Old 10-13-2006, 09:43 PM   #6
CaddyGrn
Profile:  1963 16' Bambi
Yreka , California
After you see your insulation, it might help you make up your mind. Ours had lots of mousie tunnels...
Even if clean and dry, I would upgrade ~ you don't want to take the skins apart again, do you?
We tried a combination of materials and did a sandwich layer...not sure how it will fair out. Seems pretty good so far. I think on one thread the guys said they would all get together in 40 years and reinspect to see who was right!
Mrs. NorCal Bambi (traveling in S Tardis)
CaddyGrn is offline   Reply With Quote
Old 10-13-2006, 10:27 PM   #7
C Johnson
C Johnson's Avatar
Profile:  1965 17' Caravel
Portland , Oregon
Images: 326
If I am towing at 80+ yrs old, I'll be doing good.
Chris AIR # 7276 WBCCI # 7276
WBCCI Forum Save Wally Forum
Photos of Project 2k5 My Blog Chris' World
My Pictures
C Johnson is offline   Reply With Quote
Replacing roof vents JAD Roof Vents, Skylights & Fans 10 04-15-2004 09:37 PM
Pipe insulation niftypkg Plumbing - Systems & Fixtures 1 09-22-2002 09:34 PM
Replacing my 64 Globetrotter Floor BobbyW Repairing/Replacing Floor &/or Frame 4 06-28-2002 11:28 AM
Replacing Black Water Tank Tamara Waste Systems, Tanks & Totes 15 06-18-2002 10:45 PM
Replacing Skins NSMITH Ribs, Skins & Rivets 8 06-04-2002 03:02 PM
