Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 09-25-2003, 02:05 PM   #1
cherring
Profile:
replacing aluminum on exterior
I need someone to please offer guidance on the type of aluminum I need to buy to repair a flat section on '61 Ambassador. I recall that Aircraft Spruce is the place to get it but I need someone to tell me which item to order. They have them listed as:
2024T3
2024-0
6061T4
6061T6
6061-0
7075T6
7075-0
I also need to know the thickness needed. Thanks.
cherring is offline   Reply With Quote
Old 09-25-2003, 02:51 PM   #2
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
2024-t3 AlCad .032 is what would be through at least 63 for the exterior.
Yep that's the most expensive. 13.75a ft.
I just ordered some from http://www.airpartsinc.com/ yesterday. http://www.airpartsinc.com/catalog-gif/Page03.htm is the aluminum information.
They sell coil. Advantage to coil is they can stick it in a tube and ship it UPS. To ship a full sheet it has to go freight because it's oversized. Probably double to trippled the shipping charges. Shipping for 14ft of the stuff was only $27 to Atlanta.
Disadvantage is it will want to stay in a coil till you get it rivited on. As long as it doesn't get kinked once it's riveted you cannot tell the difference.
Airparts is also half the country closer and they are billing actual shipping charges (I don't know how the other company bills) I believe so it should cost less to get it to you.
The lady that answered the phone was VERY nice and very knowledgable on the materials. Took the time to answer my questions. Family run buisness I believe.
If it's a large sheet you might want to buy some of the temporary fasteners and the tool for them. Once you drill a hole you stick these in till your ready to rivet and it will hold the peice.
http://www.airpartsinc.com/catalog-gif/Page18.htm is the page they are on.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 09-25-2003, 03:08 PM   #3
cherring
Profile:
Thanks for the info. I just ordered what I needed.
I am replacing the center piece above the window on the end cap.
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 5 09-24-2006 12:17 PM
Interior Aluminum Replacement swebster Upholstery, Blinds, Walls & Interior Finishes 34 02-24-2005 10:14 PM
Cleaning Agent (Aluminum Exterior) Cat Cleaning, Stripping & Polishing 12 04-18-2004 05:54 PM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 06:49 PM
test
