Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 09-07-2014, 06:24 PM   #1
binkers's Avatar
1993 34' Excella
Portland , Maine
Replacement segment seam sealing and rivet sequence
I am in the process of replacing 2 rear corner segments on my '93 Excella. I am ready to permanently affix the lower segment to the frame (upper to follow) and curious about the proper way to seal the vertical lap seams and horizontal rib contacts. I removed the adhesive tape material that was present between the original segments and ribs but wondering if this or seam sealer tape should applied between the frame and new segments? I should also add that this is an exterior-only repair, so I have no access to caulk seams from behind once in place.
I am also curious to know if there is a preferred rivet sequence for these corner segments. Start in the middle and work towards the vertical lap seams?
A lot of work to get to this point and don't want to blow it now...Any advice, tips and tricks on this is much appreciated!
binkers is offline   Reply With Quote
Seam sealing from the inside? ironheadxlch General Interior Topics 19 09-04-2015 08:08 AM
interior seam sealing GR8DANE Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-09-2013 11:58 AM
Seam sealer or seam tape silver 67 Ribs, Skins & Rivets 1 07-30-2013 12:53 AM
Need Advice on Seam sealing material nm1oqrz Ribs, Skins & Rivets 4 02-16-2011 11:44 AM
Seam sealing - again Fyrzowt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 11-08-2006 12:01 PM
