Old 03-21-2019, 04:57 PM   #1
Sweatpants
Sweatpants's Avatar
1975 26' Argosy 26
Shenandoah , Iowa
Replacement for exterior trim rivets
I’ve removed the exterior aluminum trim strips to refinish them, my question is: can I use screws to put them back on with? They would be covered by the vinyl strips.
What type and size screw?
How would I seal them and what product would I use?
Sweatpants is offline   Reply With Quote
Old 03-21-2019, 05:01 PM   #2
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
try #8 3/4" stainless and use a dab of trempro 635. This will let you go back to 5/32 rivets later if you wish. If the rivets you drilled out were 1/4" you may need to use #6 stainless to not enlarge the hole.
1991 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 03-22-2019, 02:19 AM   #3
Sweatpants
Sweatpants's Avatar
1975 26' Argosy 26
Shenandoah , Iowa
Using screws to replace rivets
I am afraid some of the holes are already a little stretched out, not pretty getting some of those rivets out. I better use the #8’s I guess. Good thing it won’t show. I guess I better loosen up the purse strings and get some riveting tools. It will be awhile but I will post a picture when I get started on it. Got to get it painted first. Thank you very much, especially for the quick response.
Off topic, but you wouldn’t by any chance know of any service providers in my area that would know how to paint a stripped aluminum Argosy, got a dent in the front steel cap that needs fixed also. Anywhere within 200 miles of Omaha/Council Bluffs area could work. I best start looking now. Thanks again.
Old 03-22-2019, 05:24 AM   #4
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Been there done that on an Airstream trailer. Yep #8 3/4” stainless. Sikaflex to seal.
http://www.airforums.com/forums/blog...ehind-it-2971/
Dept of “OverKill”
Old 03-22-2019, 09:17 AM   #5
1996 25' Excella
Tillsonburg , Ontario
I would think you can get anyone to paint it, and fix the dent which will just be filled and sanded over. A truck painter would know about aluminum, and probably have the big bay needed to get it indoors and dust free.
JCW
JCWDCW is offline   Reply With Quote
Old 03-22-2019, 02:22 PM   #6
Jeffersonville , Kentucky
A pop rivet tool is $20
100 aluminum rivets $5
Stainless screws would cost me more ( maybe )
You don't need a buck rivet gun and tools for this
I have never had an Argosy, but considering that it is painted, seems that any good auto body shop could pull dents and even "bondo" and paint.
But then finding a "good" shop might be hard
Dremel is offline   Reply With Quote
Rivets, Rivets, Rivets PSU1981 General Repair Forum 3 07-17-2018 12:02 PM
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 12:53 PM
Buck rivets or Olympic rivets? Sparkygus Ribs, Skins & Rivets 20 02-28-2009 08:33 AM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 10:00 PM
exterior trim rivets skip Ribs, Skins & Rivets 4 08-15-2003 07:33 AM
