Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 10-20-2004, 08:05 PM   #1
wol
Profile:  1974 27' Overlander
memphis , Tennessee
replace skin or patch
the skin between bumper and the rear hatch has fallen apart due to rearend sag and rotten bathroom floor. I have repaired the floor and frame. Now can I replace the section below the rear hatch or do I need to replace the skin all the way up to the back window?
wol is offline   Reply With Quote
Old 10-20-2004, 09:44 PM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
I'd say either way would be ok, being that the hatch occupies a large part of the skin's real estate already, however, the correct way would be to replace the entire skin section, making it look just like the original installation. I believe that your trailer is a desirable model, meaning that it's value would benefit from a proper repair.
Uwe
Old 10-20-2004, 10:52 PM   #3
Jalina
AND MAC TOO
Jalina's Avatar
Profile:
Images: 36
Ours was rotten to, for the same reasons, we just drilled out the rivets along the bottom of the hatch and up the sides about 5" ,used die grinder to cut it off, used it for a pattern but making the sides about 1 1/2" taller for overlap and applied sikaflex,riveted back in place. Can hardley tell unless you know it is there. Check our photo gallery and there is a pic of the piece we cut off setting on top of the hatch when we had the rear end opppend up. Hope this will give you another idea to ponder over.
good luck
Mac
Mac&Jalina
Jalina is offline   Reply With Quote
Old 10-20-2004, 11:29 PM   #4
wol
memphis , Tennessee
working on the skin bothers me more than anything Icould do on the whole trailer. that is why I was wanting to cut apiece that would go half way up the rear hatch to the bumper and not go up to the window. I can get a piece of 2024 that is 2ft by 4ft from Mcmastercarr for around 77 dollars compared to over 100 dollars for a 4 by 8 sheet that I will not use that much of.
Old 10-21-2004, 12:15 AM   #5
wol
memphis , Tennessee
good luck
Mac
that is what i thought about doing.
Old 10-21-2004, 08:11 AM   #6
markdoane
Profile:  , Minnesota
Images: 59
OUCH! Try: http://www.aircraftspruce.com/catalo...eet_2024t3.php or http://www.wicksaircraft.com/catalog...892/index.html
Non-contributing deadbeat.
Old 10-21-2004, 11:10 AM   #7
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
www.airpartsinc.com $12.80 a ft (ftwide) any length up to 50ft.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 10-21-2004, 07:02 PM   #8
wol
memphis , Tennessee
thanks to everyone for the information on how to repair my trailer and get the material I need! thanks billy
Skin replacement Ken J Ribs, Skins & Rivets 285 09-28-2008 04:31 PM
Is a patch so bad? CampSayler Ribs, Skins & Rivets 22 10-12-2004 11:44 AM
How do you patch Bullet holes? 59toaster Ribs, Skins & Rivets 5 10-26-2003 09:08 PM
need to replace the wheel...are there jacking points? 60traveler Towing, Tow Vehicles & Hitches 1 06-25-2003 04:05 PM
Remove belly skin -- all or nothing? pilgrim_still Belly Pans & Banana Wraps 1 06-21-2003 07:50 PM
test
