Old 06-04-2012, 03:47 PM   #1
dkrukosky's Avatar
1975 27' Overlander
Elkton , Maryland
replace olympic with Buck rivets???
it looks like at some point in its life mechazilla had one of the long side panels replaced from the outside. it was put over the old outer skin (parts of the old outer skin are cut away. now that i have all the inner skins out should I replace the olympic rivets with buck rivets or use large quantities of vulcum to seal the olympic rivets from the inside. you can see in the photos they have been leaking.
Also why did Airstream only seal some of the inner seams?
ID:	160093   Click image for larger version
dkrukosky is offline   Reply With Quote
Old 06-04-2012, 04:06 PM   #2
(-1 Rivet_
REDSLED88's Avatar
1965 20' Globetrotter
Jackson , California
Buck Rivets
I would replace with Buck if I had the access, tools and rivets.
Why not?
Not sure about the sealant,
Good luck,
TIMK
Thanks in advance!
TAC CA-77
REDSLED88 is offline   Reply With Quote
Old 06-04-2012, 05:03 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Dunno about the sealant but I would much rather have a buck rivet than a Oly any day.
Aaron
WBCCI #XXXX AIR #2495
Old 06-04-2012, 05:23 PM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Since you already have the inner skins off, I would go back and remove the old skin and buck the replcement skin in place. You most likely will not ever have this opportunity to "do it right" again. How often are you going to be restoring your trailer - once every 35-40 years at most?!
However, overlaying a new skin over the old damaged one is "standard practice" for most Airstream dealership repairs on dammaged or punctured panels...
Shari
Old 06-04-2012, 05:30 PM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Shari
Funny you mention that 35 year mark...
I FINALLY have gotten around to reworking the rear on my 1975, that makes it 37 years since it left the factory. I plan to make a 50 year repair on it.
Aaron
Old 06-04-2012, 05:51 PM   #6
1981 31' Excella II
New Market , Alabama
There is no sealant on that joint because the panel was replaced from the outside.
Perry
Old 06-04-2012, 06:07 PM   #7
dkrukosky's Avatar
1975 27' Overlander
Elkton , Maryland
yea I realize these repair joints would not have sealant but there are other factory seams that do not have any either.
Old 06-05-2012, 08:38 AM   #8
dkrukosky's Avatar
1975 27' Overlander
Elkton , Maryland
Is there any good way to get the old white caulk off? Its surprisingly still soft and gooey.
Old 06-05-2012, 05:22 PM   #9
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Mineral spirits or paint thinner should thin it out. IIRC it is butyl which remains tacky for life as long as it isn't exposed to sunlight.
Aaron
Old 06-06-2012, 06:20 AM   #10
dkrukosky's Avatar
1975 27' Overlander
Elkton , Maryland
so should they be re sealed with Butyl or with Vulkum?
Old 06-06-2012, 06:43 AM   #11
1981 31' Excella II
I believe most use this Trempro-626 which is supposed to have more working time than the 635. The white crap that AS uses cracks and has no elasticity. This stuff won't crack.
Tremco TremPro 626
Perry
Old 06-06-2012, 08:25 AM   #12
Replacing an Olympic rivet, with a buck rivet is easy enough, BUT remember that an Olympic rivet is 5/32 of an inch in diameter and the buck rivets that match are 1/8 inch in diameter.
That in itself, will weaken the attachment.
Old 06-06-2012, 09:06 AM   #13
1981 31' Excella II
Can he go to larger diameter bucked rivets?
Perry
Old 06-06-2012, 09:17 AM   #14
(-1 Rivet_
REDSLED88's Avatar
Removing Sealant, installing rivets
There are a couple ways to remove old sealant. You can try mineral spirits and see if it cuts into it. If not I use stripper or MEK will work.
VTS make a silicone remover that works pretty well, it's a little different, but works good on old silicone. Also 3M makes a SR RADIAL BRISTLE DISC, try 4 discs of 3" in size on a 90deg. die grinder and it will take old silicone off.
Some have even used gasoline (Although I've never tried that and must make the disclaimer that I personally wouldn't do it), but some say it works.
Personally have never used Vulkem for the install(since been discontinued)
Howerver I do have some Trempro 625, although it sounds like some are
using Trempro 626.... different cure time.
Don't use butyl for panels, use the Trempro.
If the rivet hole is 1/8" diameter, then you can drill the hole out to 5/32" by using a #21 drill bit, and then installing AN470AD rivets
SOLID ALUMINUM RIVETS - UNIVERSAL HEAD - AN470 from Aircraft Spruce
After the hole is drilled, deburr with a 6fluted 100deg. counter sink.
http://www.browntool.com/Default.asp...&productid=797
Typical sizes for rivets (5/32" buck) are 470AD-5-4 to 470AD5-6 for exterior, but I have size 8 just in case and cut them down. No more than 1.5 diameter sticking out the back. AD have a greater sheer strength and should be used for support. (A) Rivets are soft, so only use on something not structural.
Hope this helps,
TIMK
Thanks in advance!
TAC CA-77
