Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 06-17-2015, 07:35 AM   #1
1970 27' Overlander
Houston , Texas
Repairing large crease dent
Hi guys!
I have been restoring a 1970 Overlander for the past few months. It is in great condition other than a couple of large crease dents on the rear end cap. Obviously they're not ideal, but I didn't really pay it much attention until I realized that RV parks in Austin would turn me away. In my book, out of sight is out of mind.
Has anyone had any luck with a slide hammer and some glue tabs on these larger crease dents? If not, have you tried anything that worked better? I'm not looking to replace the panel, and certainly won't be entering this one in any restoration contests. I also don't have time to take off any inner skins. I'm just hoping to reduce the shadowline a bit and start fulltiming!
Thanks for any and all advice.
Andre
aboudre1 is offline   Reply With Quote
Old 06-17-2015, 07:40 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Curious, were you actually turned away by any parks?
Only so much can be done by pulling out panel damage. Sad to say but the only way that is going to disappear is by replacing the panels or applying a large patch of some sort over the area.
MICHAEL
Old 06-17-2015, 08:08 AM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
There are several threads on dent repair (minimization). Try doing a google search from outside of the forums with "Air forums" in the search terms, and you should find several. To sum up some of those I have read, people have had fairly good luck making dents such as yours less ugly by pulling them out with glue tabs and/or suction cups. Be careful with a slide hammer, it doesn't take much to create new problems.
good luck!
Old 06-17-2015, 09:27 AM   #4
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
That kind of dent can be nearly taken out with an air powered "Body Buddy" slide hammer, dent puller as seen in these pictures.
Name:	dent puller 002.jpg
ID:	240938   Click image for larger version
Name:	dent puller 005.jpg
Name:	dent puller 022.jpg
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
Shacksman is offline   Reply With Quote
Old 06-17-2015, 11:06 AM   #5
1982 27' Excella
Huntsville , Texas
Dent repair
The dent removal looks really good. Wish the made a micro version for hail repair!
GMarugg is offline   Reply With Quote
Old 06-17-2015, 11:29 AM   #6
Alden Miller's Avatar
1993 34' Excella
, Maryland
I used the sticky tabs and a dent puller to fix mine. Not perfect but certainly better than it was. If you are not specifically looking for it you won't notice it now.
-Alden
1993 34' Excella 1000
2005 Dodge Ram 3500 Diesel
(No it doesn't have a HEMI in it)
Alden Miller is offline   Reply With Quote
Old 06-17-2015, 01:33 PM   #7
1976 27' Overlander
Astoria , Oregon
I had almost an identical dent in my 76 27' airstream. Used a grinder with a mental cutting wheel to make a slice in the wood paneling just above the curtain rail on the inside where it would not be observable. Drilled out the rivets and toke down the curtain rail. Pulled out the panel from the side window to the dent and pushed out the dent than hammered from both inside and out to decrease the affect of the crease. Re- riveted the panel in the same holes Turned out beautifully. Because of the double curve the panel needed no suport where the slice was made. 2 guys about 2 hours.
Earl123 is offline   Reply With Quote
Old 06-17-2015, 02:37 PM   #8
1965 30' Sovereign
West Allis , Wisconsin
They wouldn't let you in to camp ground? Really? Mine will never be allowed then!
I need one of those Body Buddys! The 3"-4" suction cup from Harbor Freight didn't work, surface too concave. On flatter area it let go before area crease was released.
BTW, if your dent flops back in or "oil cans", I've heard others have permanently installed hard foam between inner and outer panels. Of course, inside access is required.
65Streamer is offline   Reply With Quote
Old 06-17-2015, 06:20 PM   #9
1970 27' Overlander
Houston , Texas
Hi Shacksman,
That "Body Buddy" looks like it worked pretty well! What sort of air compressor do you need for it? I've looked online but all I've found is the suction cup piece for sale. If you have a model you recommend, let me know!
Old 06-17-2015, 06:24 PM   #10
1970 27' Overlander
Houston , Texas
Hi AW Chief,
I haven't been rejected yet, but I've had a few park owners push me back on the waiting list because of the appearance. Apparently they're getting picky in Austin these days...quite frustrating since these Airstreams look better than your typical RV with or without dents.
Old 06-17-2015, 06:26 PM   #11
1970 27' Overlander
Houston , Texas
-Alden
Hi Alden,
Great to hear! Do you remember where you purchased your dent puller? I'm not looking for perfection, just improvement!
Andre
Old 06-18-2015, 08:10 AM   #12
c177tx's Avatar
2008 19' Bambi
Images: 20
too many people from California have moved to Austin. Not the Austin of old. What happened to the days of the Armadillo and onward thru the fog days.
c177tx is offline   Reply With Quote
Old 06-18-2015, 09:29 AM   #13
1971 31' Sovereign
1973 29' Ambassador
1978 31' Sovereign
Palm Desert , California
Nowhere is the (fill in the blank) of old. My family has been in California for over 125 years. What happened to rush hour without traffic? Don't just point the finger at Californians.
Anyway, I used the small suction cups from Harbor Freight to pull the smaller dents out or where the aluminum was curved. It worked ok. I had a large one in the front corner and was able to remove the stereo cabinet and push it out from the inside. I can't do that in the back unless I remove the bathroom end cap.
CaCraig is offline   Reply With Quote
Old 06-22-2015, 05:29 AM   #14
1993 34' Excella
, Maryland
Originally Posted by aboudre1 View Post
Hi Alden,
Andre
I picked them up off of Amazon.
-Alden
Old 06-22-2015, 07:18 AM   #15
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Hi Shacksman,
Lots of them on ebay pneumatic dent puller | eBay it needs 3.5CFM at 85 lbs
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
medium, large or really, really large batteries bukib Land Yacht/Legacy Motorhomes 3 11-14-2010 10:00 PM
Roof crease Denis4x4 Roof 18 05-16-2006 05:56 AM
A Large Family Janets Husband Our Community 15 02-25-2004 08:53 AM
WBCCI: Local, Regional, or At-Large RivetED WBCCI Forum 7 01-26-2004 06:47 AM
Small or Large Penquin GoldFever Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-16-2003 09:30 PM
