Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Prev Previous Post   Next Post Next
Old 09-10-2007, 09:18 AM   #1
1Michigander's Avatar
Profile:  1975 24' Argosy 24
Midland , Michigan
Repairing dents in galvanized Argosy endcaps.
I have a 1975 Argosy 24 and the previous owner put two good-size dents in the top end caps. One is on the right side of the trailer in the front and the other is on the left side in the rear. These caps seem to be galvanized steel. It appears to me that I will need to remove the plastic molded endcap on the iniside by drilling out the rivits and then pounding out the dents from the inside. Am I on the right track here? Has anyone else out there repaired dents in Argosy end caps before? I would like to avoid a trip to the mothership for this. It does not affect performance of any kind and I use it regularly so I know there are no leaks. Also, once I fix the dents I want to have it painted any ideas there as well would be very welcome.
If God had a refrigerator, your picture would be on it.
Last edited by CanoeStream; 09-10-2007 at 09:30 AM. Reason: Returned to forums standard default font.
1Michigander is offline   Reply With Quote
Cracks in endcaps...and more Tin Lizzy General Interior Topics 1 08-14-2007 04:25 AM
'59 fiberglass endcaps 1959newbie 1958 - 1963 Overlander 14 12-14-2006 08:26 AM
Has anyone fabricated new endcaps? soldiermedic Upholstery, Blinds, Walls & Interior Finishes 7 11-17-2006 06:41 AM
Replacing Argosy MH galvanized endcaps. . . TheGanzman Argosy Motorhomes 6 09-30-2005 06:32 PM
new member - endcaps and frame? ed moller All Argosy Trailers 5 01-06-2005 08:16 PM
