Old 12-15-2019, 04:11 PM   #1
1967 24' Tradewind
Berlin , Berlin
Repair Rib or Leave it?
Hi guys.
We're about to put in the interior panels of our 1967 Trade Wind.
THer must be a sprung door at our trailer at some point.
So the rib close to the door is slightly bend –*about half an inch.
Would you repair that? And how?
Or would you leave it as it is?
Here are som pics?
THanks.
All the best from Germany.
Severin
severin is offline   Reply With Quote
Old 12-15-2019, 04:19 PM   #2
1967 24' Tradewind
Berlin , Berlin
here you go:
ID:	357719   Click image for larger version
Old 12-15-2019, 05:12 PM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Personally I would repair it. The aluminum the ribs are made of is pretty soft and the contour can be restored quit easily. Remove the skin rivets that are common to the bent rib and hammer and dolly the damage out.
Old 12-15-2019, 06:54 PM   #4
1966 22' Safari
Fredericksburg , Texas
We had the same issue on the 55 and did exactly what Aerowood recommended. Worked out well and wasn’t difficult. Good luck
Bubba L is offline   Reply With Quote
Old 12-16-2019, 03:47 PM   #5
1967 24' Tradewind
Berlin , Berlin
ok. Thank you!
I kind of hoped you guys would say: Leave it! ;-)
How exactly are you doing it? The rib is also bend together a little bit.
Thank you! ALl the best, Severin
Old 12-17-2019, 11:49 AM   #6
Aerowood's Avatar
Arvada , Colorado
It’s kinda hard to explain, using a dolly block or a bucking on the concave portion hammer the opposite side flat.
With the frame dented don’t you have a dent in the skin?
Old 12-17-2019, 12:53 PM   #7
r carl's Avatar
Lin , Ne
Do you know someone that could straighten it for you?
Interior vinyl and wood layer, to leave or not to leave? amaelish General Interior Topics 0 05-29-2017 01:18 AM
Rib repair or replace? JIMandPJ Ribs, Skins & Rivets 5 05-02-2011 03:31 AM
Damaged Rib repair rpark01 Repairing/Replacing Floor &/or Frame 8 05-19-2009 03:34 PM
The first day. Broken Rib? Charming Wino 1974 - 1977 Overlander 12 03-07-2004 07:11 PM
bent/cracked rib? Jabba Ribs, Skins & Rivets 1 10-27-2002 07:04 AM
