Old 08-07-2015, 10:53 AM   #1
1977 31' Excella 500
Bonnyville , Alberta
Repair or Replace?
Should I see if this can be repaired or just replace? What would this "bumper" piece be called?
'78 Excella 500 31'
Name:	ImageUploadedByAirstream Forums1438966394.980588.jpg
Zenstream1 is offline   Reply With Quote
Old 08-07-2015, 11:10 AM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
If it were me I would try to straighten first and if unsatisfied or unable then resort to replacement
Old 08-07-2015, 11:26 AM   #3
1974 Argosy 20
Kooskia , Idaho
I think, but not sure, that is a pretty rare piece and may not be available at all, and if so will be costly. Check with Andy at Inland RV, he knows a lot about that vintage of an Airstream and what parts are to be found.
Old 08-07-2015, 11:51 AM   #4
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I assume you are just talking about the low part that seems to join the body to the bumper trunk. That piece is likely to be made of the same thick, soft aluminum that banana wraps are made of, meaning that you should be able to remove it and straighten it out so that it looks about as good as new. It is going to be very difficult to find that part new, sitting on a stockroom shelf, and it will be pretty rare to find as a used part as well.
That's a pretty nasty dent in the corner segment as well. Are you planning on rpairing or replacing that as well?
good luck!
Old 08-07-2015, 12:00 PM   #5
I think we will pop and polish the upper large dent.
The lower bumper piece is all we are thinking of replacing.
Old 08-07-2015, 12:17 PM   #6
Name:	ImageUploadedByAirstream Forums1438971430.332041.jpg
Looks like a pretty intense crumple to try and pound out though! 😳
Old 08-07-2015, 12:18 PM   #7
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Repair or Replace?
Is the bumper extension painted?
If so it will be a lot easier to fix it than to find a replacement... IMO of course.
Edit>> i see it is not painted...
Maybe the best repair is to fix and then paint both sides.
Old 08-07-2015, 12:27 PM   #8
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
With patience, most of that dent can be removed, and then a bit of body filler to clean it up, paint and install.
Paint and filler will cover a multitude of small dents...
Name:	ImageUploadedByAirstream Forums1438972051.056967.jpg
Old 08-07-2015, 12:56 PM   #9
Belegedhel's Avatar
Houston , Texas
Originally Posted by Zenstream1 View Post
Attachment 244811
Depends on what type of aluminum it is made of. My front banana wraps did not look salvageable, but I got them reshaped with a rubber mallet, using a bag of sand as an anvil, and then smoothed them out with an English wheel. You would never guess to look at them now that they were headed for the scrap bin (before I realized how hard to find a replcement part was).
Old 08-07-2015, 01:29 PM   #10
Thx guys^
To Replace or Not to Replace 65air Towing, Tow Vehicles & Hitches 3 03-29-2013 12:58 PM
2 replace decal or not to replace? nustreamer Clearcoat, Exterior Paint & Trim 1 07-15-2011 10:28 PM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 06:20 AM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
Sink...Repair or Replace?? COArgosy78 Sinks, Showers & Toilets 17 08-05-2003 03:28 PM
