Old 12-24-2010, 07:47 AM   #1
1970 23' Safari
stuart , Florida
removing wall panels
Is it safe to remove all wall panels (trailer would just be floor and shell) and tow the trailer a short distance (less than 10 miles)??? Or should I tow it to the final destination and then remove all wall panels??? I'm new at all this so I'm sure to have lots of questions and I apreciate any help!
goose is offline   Reply With Quote
Old 12-24-2010, 08:28 AM   #2
pbearsailor's Avatar
Port Hadlock , Washington
It'll tow just fine that way.
Welcome to the forums and questions are never a problem!
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 12-24-2010, 09:05 AM   #3
You can tow it just fine that way.
One thing to keep in mind is that, once you arrive at your working destination, you'll need to block it up really well to support the front and rear and ensure the frame is level, before doing any frame repair/floor replacement/panel re-installment. Those interior panels do provide support to the overall structure, and the front and rear can potentially sag when you remove them. If you want the panels to go back in cleanly, you'll need to make sure the frame is level and even.
Good luck!
Old 12-24-2010, 04:20 PM   #4
1970 23' Safari
stuart , Florida
thanks for letting me know about the sag that makes perfect sense but i had not thought of that!
Flooring replacement and removing under panels AArchitect Repairing/Replacing Floor &/or Frame 8 11-13-2010 03:18 PM
Back of interior wall panels zenman Upholstery, Blinds, Walls & Interior Finishes 5 09-22-2009 02:59 PM
Installing stainless steel wall panels mcneon Cabinets, Counter Tops & Furnishings 25 04-13-2007 04:48 PM
Peeling wall panels wacnstac Cabinets, Counter Tops & Furnishings 3 11-30-2006 08:11 PM
need help removing bath wall rvlover General Interior Topics 1 10-27-2005 03:24 PM
