Old 10-31-2007, 11:17 AM   #1
Brow324's Avatar
2007 27' Safari FB SE
Scurry , Texas
Removing tree limb scratches?
any advice on buffing out or other techniques to remove light tree limb scratches from the side of our A/S? Was going to try polishing compound but thought I'd ask first.
'07 27 FB - H.A.
Brow324 is offline   Reply With Quote
Old 10-31-2007, 11:32 AM   #2
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Brow324,
Depending on just how deep it is..You might be able to lightly buff it out.
Since your unit is so new, I wouldn't recommend getting too aggressive with the compounding. I would hate to see you end up redoing the clear-coating as the original application on your unit's is applied during manufacturing..prior to it's arrival at the factory.
Do you have any pictures?
53flyingcloud is offline   Reply With Quote
Old 10-31-2007, 11:35 AM   #3
B25guy's Avatar
2003 25' Safari
Yakima , Washington
Images: 20
don't use compound!
I believe using any type of abrasive on the finish will make matters worse.
I have similar scratches on mine and over the last couple of years, they've faded to almost imperceptible. I've waxed the finish several times and that seems to help them "heal".
Marc
B25guy is offline   Reply With Quote
Old 10-31-2007, 12:01 PM   #4
Valhalla2Go's Avatar
1968 26' Overlander
2008 27' Safari FB SE
CHICAGO , Illinois
Brow:
I would do a good search on forum as there are many prior threads on polishing, removing scratches, tar, etc and almost any of the buffing threads start with a step to remove scratches from years of use - typically a use of higher grit compound or an abrasive pad. research and tread as lightly as possible to avoid making matters worse. I plan to do the same when I find the 140 hours of time to polish our 68'.
Valhalla2Go is offline   Reply With Quote
Old 10-31-2007, 12:02 PM   #5
_
Originally Posted by Brow324
any advice on ...techniques to remove light tree limb scratches
hi brow'....
STOP! DON'T MAKE IT WORSE....
make it betta!
i use
meg's scratch x...
Meguiar's Scratch X Scratch Remover
AND
3m perfect it 3000, also known as 3m perfect it swirl mark remover, also known as 3m perfect it foam polishing pad glaze light...
3M Perfect-It Swirl Mark Remover for Light Paints was created specifically for whites, lights and metallics!
both of these products are microfine and will take down the scratch edges with VERY LITTLE risk of clearcoat insult.
IF your damage is down to the METAL, (does a finger nail catch in the scratch?) nothing can undo that....
but with the above products, a microfiber pad and some poly sealant coating it can look pretty good and will be well protected....
i've worked on some ohmygoodnessuglynasty scratches that were completely removed with no visible traces remaining, using the products listed above.
the poly sealant coatings have been covered in other threads....
a/s does sell a spray acrylic clearcoat touch up and auto clearcoat touch ups can be used.
these products may cover the bare metal...
my experience is that these items aren't often applied correctly and with adequate prep...
so the results usually look much worse than the original damage.
the info above applies ONLY to the clearcoated alcoa panels from recent production, NOT the plasti-coat or al-clad aluminum of bygone dayz...
cheers
2air'
Old 10-31-2007, 12:06 PM   #6
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I've used Walbernize super seal. Takes them right out...as long as they are light/mild.
Old 10-31-2007, 12:17 PM   #7
1968 26' Overlander
CHICAGO , Illinois
You can take 2airs and Silver Hostess Goodness replies to the bank! In my haste to trick or treat I neglected to look at your model year which calls for a delicate touch on the newer skins. Of course most of us never graze anything in our travels nudge nudge wink wink
Old 10-31-2007, 12:29 PM   #8
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
I can testify to the Walbernize. It works good for hiding scratches.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 11-03-2007, 08:36 AM   #9
Brow324's Avatar
Scurry , Texas
The limb scratches are very light...only in the clear coat....thanks for all the good advice ...I will tread lightly!
'07 27 FB - H.A.
scratches,lightning and other issues strayhorse General Repair Forum 8 12-28-2008 03:19 PM
Wife Scratches Nose Darrell Root Our Community 8 10-10-2007 12:34 PM
removing scratches from tree branches millvalleyca Cleaning, Stripping & Polishing 3 08-06-2007 07:34 PM
Scratches Pharmdawg Ribs, Skins & Rivets 1 08-30-2006 10:25 PM
The dreaded falling limb!!! Silvertwinkie Our Community 7 07-28-2003 01:13 AM
