Old 02-26-2010, 08:28 PM   #1
1970 23' Safari
Ventura , California
removing rivets
I am about to remove the belly pan from my 1967 overlander international airstream... What is the best (and fastest) way to remove the rivets? Also which tools are the best to use? (brand name and everything) Inland RV has a rivet tool on sale: http://www.inlandrv.com/catalog/images/bucktool.jpg"][/URL]
Would this be a good one to re-rivet a new aluminum belly pan?
What are the differences between the interior rivets that hold the vinyl skin to the interior frame compared to the exterior rivets? (be specific please!)
jaminalee is offline   Reply With Quote
Old 02-26-2010, 08:54 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The tool you are looking at is for buck rivets. You need access to both sides to buck a rivet. The belly pan rivets are blind rivets which means that you do not have access to the back side. You would use a tool like this.
Richard
Old 02-26-2010, 09:20 PM   #3
Images: 59
You can also buy the special "large flange" pop rivets to reattach the belly pan from Vintage Trailer Supply.
Old 02-26-2010, 10:50 PM   #4
1970 23' Safari
Thank you! So helpful!
Old 02-27-2010, 12:50 PM   #5
1970 23' Safari
Real quick: what's the best way to remove belly pan rivets?
Old 02-27-2010, 01:38 PM   #6
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
If you are using these rivets (You can get these rivets at Fastenal)
Then a high speed drill and the Ideal drill bit size is #11 bit but a 3/16" bit will work.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Lousy Rivets!/Weak rivets sunk the Titantic? 1956Safari Off Topic Forum 14 04-18-2008 01:35 PM
removing original rivets kamo Ribs, Skins & Rivets 7 10-27-2006 09:57 PM
removing Olympic rivets pinkflamingoes Ribs, Skins & Rivets 1 06-06-2006 03:24 PM
removing rivets Tin Hut Ribs, Skins & Rivets 6 08-30-2003 07:34 AM
