Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 10-25-2012, 02:58 PM   #1
Removing rivet stubs
One of the many previous owners of my 74 Argosy Motorhome removed the front grille assembly so they could remove the 454 for use in a circle track race car
The removal process left a gazillion of rivets like these sticking out.
What would be the easiest and best way to remove all of these rivet stubs?
1975 24' Argosy Motor Home
Old 10-25-2012, 03:14 PM   #2
North Charleston , South Carolina
drill baby drill..
HairCream is offline   Reply With Quote
Old 10-25-2012, 03:22 PM   #3
Originally Posted by HairCream View Post
drill baby drill..
Easy for you to say
My only thought was to use a cutoff wheel to trim them fairly close to the aluminum skin and then drill them out.
My real hope was that someone would have a magic wand that I could just wave over the rivet stubs and they would fall out
Old 10-25-2012, 03:48 PM   #4
My real concern is how tall they are. I'm going to see how easy the process is on Sunday. Who knows, with luck I might be done Sunday as well
Old 10-25-2012, 05:24 PM   #5
DanielB's Avatar
1974 31' Excella 500
I'll give it 10 minutes. Just jam that drill blade in the hole and guide it in easy. Angle the drill to keep it going in the center of the rivet. Easy Peasy lemon squeezie.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 10-25-2012, 06:28 PM   #6
pgr32e's Avatar
1974 27' Overlander
Sault ste Marie , Ontario
If they're hollow all the way through, then drilling them will work fine. If however they still have the stems in them, then I like your idea of cutting them off close to the surface and then drilling, especially if the stems are harder than the body of the rivet......Phil.
pgr32e is offline   Reply With Quote
Old 10-25-2012, 06:47 PM   #7
DanielB's Avatar
Yes, there could be steel stems in there, but you can improvise like a jazz man instead of getting all lawyer'd up from the get go.
Take a pair of pliers and see if you can push the rivets in some first. If they go in they the stems become a non issue.
- Andrew Carnegie
Old 10-26-2012, 06:25 AM   #8
1981 31' Excella II
New Market , Alabama
Try a sharp wood chisel and a hammer. If they are aluminum core they will shear right off and you can drill what is left.
Perry
Old 10-26-2012, 06:43 AM   #9
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
I used a dremel cut-off wheel to trim them as flush as possible, and then used a nail set to push them out of the hole. If the rivet doesn't push out easily, then you can drill them out. Cutting them flush helps ensure the drill bit will not wander off the rivet and enlarge the hole.
Chris
Old 10-26-2012, 08:04 AM   #10
I think a hammer and punch would be problematic as there is no support around the opening. If I had a third hand I could provide backing support, unfortunately I'll be doing this by myself. I'll try nipping them off close to the shell and then see if I can pull them through from behind. I think I can get to the back side on most if not all of them.
I should know Sunday which one of these approaches works
Thanks!
Old 10-26-2012, 08:33 AM   #11
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
It looks like you can get to the back of the rivet where it's mushroomed and use some side cutters/ wire cutters and easily cut the mushroomed part of the rivet. The rest of the rivet be easily pulled out by hand.
desertair27 is offline   Reply With Quote
Old 11-05-2012, 05:34 AM   #12
Just thought I would follow up with the method that worked the best. I tried using new (i.e. sharp) cutters and that method pretty much didn't work due to mushrooming the heads.
I then tried drilling and 9 times out of 10 that method worked. The real problem was there was no back support for the aluminum so any sort of hammering wasn't really possible since I don't have three hands, one for back support, one for holding the punch and one for the hammer
Nipping them just mushroomed the heads making it difficult to get them out. Drilling worked the best by far.
Thanks!
Old 11-05-2012, 06:57 AM   #13
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
They look like blind rivets put in backwards. Drill them out with a 1/8 drill and replace them in the opposite direction. If they are in a place that will show use Olympic rivets.
Old 11-05-2012, 07:21 AM   #14
They were blind rivets installed from the front. The rivets were holding the Argosy motorhome ABS front grille to the shell. Some of the rivets actually fastened to the aluminum front structure. On an Airstream motorhome the front shell is riveted to a cast aluminum frame work. A few of the rivets were fastened to this frame work, the rest were in the aluminum skin.
The rivets do need to be installed from the front and I think using Olympic rivets through the skin would be a good idea. I'll look into that when the time comes to re-install the front grille.
Old 04-12-2013, 07:26 PM   #15
2010 20' Flying Cloud
Fremont , California
I'm no riveter, so I've been practicing on scrap. I shaved them off OK with a Dremel stone wheel. I then cut a hole the size of the rivet head in a scrap so I could sandpaper the heads without scratching the surroundings. So far so good.
Then when I tried to drill them out, everything was fine until the rivets started to spin. At that point the rivet head is stationary against the drill and both spin together. Gak!
Is that likely when I try to drill out the real thing?
Are spinning rivets because I did a poor job of practice riveting? Olympic RV 6607-5-5 rivets.
If my practice riveting is bad, can you suggest what I might be doing wrong?
Jim Light
jlight is offline   Reply With Quote
Old 04-13-2013, 06:04 AM   #16
For a few rivets a dremel or similar would be ok. If you've got literally hundreds of rivets to replace I'd strongly suggest the correct rivet shaver. Not the cheapest in the world but I'm totally glad that I bought one. Fast and easy and does it right the first time.
Not uncommon at all to have rivets spin, at least when drilling pop-rivets. Buck rivets don't spin nearly as often. Using the right size drill bit does help. Generally pop-rivets will require 1/8" drill bit.
Doesn't sound like you're doing anything wrong to me.
