Old 07-19-2012, 05:37 AM   #15
Eagle & Bear's Avatar
1976 29' Ambassador
Madison , Officially SD but are traveling full time.
Someone mentioned "o"rings that are used with the Olympic rivits. Where can we purchase those?
Eagle & Bear is offline   Reply With Quote
Old 07-19-2012, 05:58 AM   #16
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Some are sold with neoprene O rings, some are not. The rings will dry out and fail and I do not use them. Use some sealant on the rivet when you install it for a longer lasting seal.
Richard
Old 07-19-2012, 06:14 AM   #17
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Do NOT use "O" ring Olympics.
Old 07-22-2012, 09:58 AM   #18
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
Originally Posted by REDSLED88 View Post
I think I paid just under $200 for a 4x12' roll of aluminum (request it to be rolled).
TIMK
just wondering the source, did you order online or from a local shop?
Best regards
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
Old 07-27-2012, 08:32 PM   #19
(-1 Rivet_
REDSLED88's Avatar
1965 20' Globetrotter
Jackson , California
O ring olympics
Eagle bear.... that's is exactly what I had originally on this panel, and they were not going to make the cut, so out they went.
I have successfully removed the panel. A little boo boo on my part, I needed to remove 2 more rivets going up and then I waited for a hot day, rounded off a putty knife and used some elbow grease and whalla.... out she came.
All in all it took about 10 minutes, I've just been hobbling around after my knee surgery, so I wasn't getting too crazy, but it's removed.
I'll post pictures on my next post.
Now the fun part, making a new skin, drilling it out, getting it clecoed and then buck riveting (will Trempro 625 of course).
I am a little scared of the buck riveting personally.... maybe someone in the Sacramento Area would like to help a fellow airstreamer out. I have all the tools, just need some experience.
Thanks in advance!
TAC CA-77
REDSLED88 is offline   Reply With Quote
Old 02-18-2015, 09:16 PM   #20
GlamperGirl
Timk I am about to start removing panels too. How did it go for you?
My banana wraps were wrecked and I wrecked them more.
Any ideas?
I am tempted to just put them on anyway.
I am afraid to hammer the dents out!
Will get you my measurements and some photos of my project. Cruise around for more albums that are public,
https://plus.google.com/photos/11042...63767839658481
Dena
thumbelinadj is offline   Reply With Quote
Old 02-18-2015, 10:03 PM   #21
Kevin245's Avatar
Removing exterior corner panel
Any ideas?
Dena
Dena,
I use an English Wheel to work banana wraps. A custom body shop may smooth yours out for you if you don't have access to one.
Regards,
Kevin
Eleanor Roosevelt
Old 02-18-2015, 10:18 PM   #22
GlamperGirl
Hi Kevin- I bought one and IT WAS HEAVY!! I couldn't even get it out of the truck. I lost hope and faith I could learn ANY OF IT! SO i returned it. I think I need to go find a hot rod dude and ask for help. I keep hearing $$$$ from others! THANKYOU!
Old 02-19-2015, 01:49 PM   #23
Kevin245's Avatar
Any old school body guy or hot rodder should be able to knock this out for you. Beer and pizza will get you some wheel time in many small shops in my neck of the woods.
Eleanor Roosevelt
Old 02-19-2015, 04:09 PM   #24
(-1 Rivet_
REDSLED88's Avatar
Use a shot put
Any ideas?
Dena
I just bought a shot put on craigslist ($12) and heated the banana wraps a little if it's cold.... I did mine in summer when it was hot.
Just rolled it around to get the shape I wanted.
I put a towel underneath to not scratch it anymore.
Then I just polished them up.
There not great, but good enough.
I'll get a picture later tonight,
TIMK
Thanks in advance!
TAC CA-77
