Old 11-30-2011, 05:16 PM   #29
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Originally Posted by perryg114 View Post
So give us details on how it was done. Looks like you glued some pegs onto it?
Perry
glue sticks and a pack of dent puller stems
Dent Pulling Glue Sticks - PDR (Glu-Stix)
Then a slide hammer to pull on the stems
Glue stems to aluminum
attach slide hammer to stem
gently use weight on slide hammer to pull dent
work your way around
you can also get a kit
http://www.gluepullers.com/
Darkspeed is offline   Reply With Quote
Old 11-30-2011, 05:35 PM   #30
1981 31' Excella II
New Market , Alabama
The is good info to have. Is there a favorites thread function on here so you can same important threads? I am on two or three different computers in a day and the links are never on the machine I am on.
Well I don't have any big dents yet but I do have a lot of small hail dents and rock dents on the front.
Perry
Old 11-30-2011, 06:50 PM   #31
webspinner's Avatar
Menlo Park , California
Perry, in the bar at the top of the thread, there's a button labeled "thread tool" and in the pull down menu from that, there's a place to "subscribe to this thread." You can choose whether or when to get email updates.
To find the thread again, go farther up the AirForum web page and look for "quick links" towards the right. In that drop down menu, you can find your subscribed threads.
Barbie
Our travel and renovation blog: http://tinpickle.blogspot.com/
webspinner is offline   Reply With Quote
Old 11-30-2011, 08:41 PM   #32
Martinez , California
The "hot torch cold rag" trick is how body shops used to fix hail dents. A welding supply store can sell you a heat sensitive crayon that you can mark the metal with - when the crayon mark changes color you stop heating. But you'd have to know what temperature you wanted to heat the metal to in order to get the correct crayon. Most auto body shops won't touch aluminum - if it's bent, you need a new one.
Mr.Bill is offline   Reply With Quote
Old 11-30-2011, 11:02 PM   #33
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Originally Posted by 62overlander
a pictures worth a thousand words. Heres 3000 words.
Love it,thanks for sharing!
desertair27 is offline   Reply With Quote
Old 12-01-2011, 03:06 AM   #34
Baltimore , Maryland
There was nothing fancy and nothing I came up with on my own. On The Vintage Airstream Podcast, Colin Hyde talked about hot melt, vise grips, and an elevator bolt as a dent puller. No fancy tooling, no kits and no slight of hand was employed. I tried it and it worked very well. My employee, Wayne told me I was wasting my time. Ace was skeptical, and I was confident it was going to work(because I did not want to take the front end cap out). Unfortunately, I am always confident right up until it doesn't work, then I become doubtful. In this case, confidence paid off.
Now please note, this dent is not 100% gone. The skin was creased and that can never be properly repaired. The up side is at rallies, no one will be saying "yeah, turn right at the shiny Caravel with the big dent in the front end cap"
Old 12-02-2011, 04:21 PM   #35
worldinchaos's Avatar
1959 17' Pacer
Long Beach , California
Or if you are like me, and addicted to the interwebs, browsing airforums constantly (during nighttime, daylight is for the trailer work), then you might end up with 200+ subscribed threads. One solution for the really important ones is to bookmark them in google chrome, which you can sync between all your computers. I do that so all my favorites, saved logins, autofill, etc are ubiquitous between my work computer and both the Mac and windows side of my home computer.
Just one solution... Or you could just not subscribe to every thread with a single interesting bit of info.
- Peter (and Marie)
TAC CA-15
1959 Pacer 18' Renovation - Knight in Shining Armor
Our Adventure Blog - Documenting our backpacking, hiking, camping, and Airstreaming
(still updating, haven't gotten to the Airstream trips yet)
worldinchaos is offline   Reply With Quote
Old 01-13-2012, 04:03 PM   #36
bilby05
bilby05's Avatar
1962 24' Tradewind
1962 24' Tradewind
Canyon , Texas
Finally had a warm sunny day and decided to take a shot at the big dent. Having previously removed the light fixture at the end of the bathtub, and enlarged the space behind the fixture, I stuck my hand in there and pushed against the bump and "sproing" it popped out. Sorta. It popped back in once, but I think once I get a "J roller" and remove the remaining divits it will stay in place and look nice. I will try to attach a "during" picture to go with the before and later post the after.
cheers, bill b.
Name:	first effort2012.jpg
1962 Airstream Tradewind
2001 Ford 7.3 Diesel
bilby05 is offline   Reply With Quote
Old 01-24-2012, 12:20 PM   #37
How flamable is the insulation between the skins?
Old 01-24-2012, 05:16 PM   #38
1981 31' Excella II
It is not flamable at all. The skin will melt way before the insulation but you might melt some wires to the skin and cause a short. I would consider using cold instead of heat. You can heat the skin up with a hair dryer and then hit it will cold to pop the dent out. There is also glue on the inside what will outgas and smoke. I just pushed some minor rock dents out from the inside on the front end cap. I have the skins off repairing leaks anyway so I figured why not fix those little dents.
Perry
Removing window frames '61 GT streamahead Windows, Doors, Locks & Vents 3 07-30-2011 09:47 AM
Had the honor to step inside a 1962 Bambi this weekend and fell in LOVE with the heat J5MM LP Gas, Piping, Tanks & Regulators 9 03-14-2011 02:52 PM
Why heat to holding tanks? Breadbug Furnaces, Heaters, Fireplaces & Air Conditioning 12 01-22-2011 10:54 AM
Need help removing rivets. Breadbug Windows & Screens 16 01-19-2011 08:11 PM
Heat Pumps Brianv512 Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-19-2011 05:15 PM
