Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 01-28-2014, 07:16 PM   #1
VtTim's Avatar
Santa Fe , New Mexico
Removing dents from Argosy steel end cap
Hello gang. I have an Argosy with a couple of dents. One seems fairly minor while the other is pretty bad. Both dents are in the rear end cap. The one on the curbside corner is particularly ugly. What can I do about them? Do I have to take out the interior and pound them out from inside?
Any ideas would be appreciated.
Name:	ImageUploadedByAirstream Forums1390961647.887395.jpg
ID:	204530Click image for larger version
Name:	ImageUploadedByAirstream Forums1390961677.052484.jpg
ID:	204531Click image for larger version
Name:	ImageUploadedByAirstream Forums1390961700.427131.jpg
ID:	204532Click image for larger version
Name:	ImageUploadedByAirstream Forums1390961720.642115.jpg
ID:	204533Click image for larger version
Name:	ImageUploadedByAirstream Forums1390961744.574782.jpg
ID:	204534Click image for larger version
Name:	ImageUploadedByAirstream Forums1390961763.324878.jpg
VtTim is offline   Reply With Quote
Old 01-28-2014, 07:35 PM   #2
Retired.
. , At Large
Tiger hair, bondo, an air sander, and some paint.
Old 01-28-2014, 07:51 PM   #3
VtTim's Avatar
Ok. Paint, I know what that is. Bondo, yup. Tiger Hair? Not sure how to get that, there aren't many tigers roaming the woods of Vermont. Air sander? Not exactly sure what that is either. Help out a layman here...
Old 01-28-2014, 07:54 PM   #4
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Those dents look very deep. I would not fill them. I would use a slide hammer/dent puller from the outside and get the panels to nearly their original shape, then weld the holes closed. Sand the paint off and fill and sand as necessary. Care must be taken not to pull the metal out too far.
Last resort, remove the interior and push out from the inside, again care must be taken not to "make more metal". Pulling or pushing can stretch the metal, and "shrinking" sheet metal can only be done with access to both sides.
Others may have a different idea.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 01-28-2014, 07:56 PM   #5
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
You may want to consult your local body shop and get an estimate.
Old 01-28-2014, 08:07 PM   #6
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Another thought......
Find another trailer that is trashed except for the end caps, and switch the end caps.
Old 01-28-2014, 08:13 PM   #7
1974 Argosy 20
Kooskia , Idaho
Tim: I would also concur that maybe a trip to a body shop might be in order. Since they are steel caps, they would be serviced like any steel auto body. That is different from the Aluminum end caps on an Airstream which I would never take to a body shop.
Do it yourself? Hmmm, probably the drilling and slide hammer idea along with bondo would be the way. I would concur that if you don't have to take out the interior end cap you will be much better off.
Old 01-28-2014, 08:15 PM   #8
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Attachment 204530Attachment 204531Attachment 204532Attachment 204533Attachment 204534Attachment 204535
Hi Tim,
Remove the end cap & bring it over. We have an English Wheel & can easily remove those dents to a level than would only require minor bodywork before painting.
Colin
Colin H is offline   Reply With Quote
1973 argosy or 1989 as??? billy1 Dollars & Cents 1 08-04-2011 07:37 PM
Some insight on how things end up the way they are Boondocker WBCCI Forum 24 04-26-2011 08:06 PM
Before I remove bath end cap Breadbug Ribs, Skins & Rivets 3 01-27-2011 01:03 PM
Aluminum end cap? Breadbug General Interior Topics 1 01-27-2011 09:54 AM
