Old 01-31-2015, 05:11 PM   #1
Airwave503's Avatar
1961 22' Spaceliner
Portland , Oregon
Reinstalling fiberglass interior endcap - holes not aligning
Putting interior skins back in, starting with my fiberglass endcap (it was the last to come out. The holes across the top of the window align as do the ones on the left and top left, but the top right and right side are off by 1-2 inches and no amount of shoving will get them where they need to be.
My best guess is that over the months that I have had it out resting on it's top edge it's warped. Anyone think if I get it really hot in there, maybe take a hair dryer to it, it might make it more plyable?
My only other guess is that some pex piping that I put in the walls is bulging out a slight bit and throwing it off.
How important is it to align with the original holes?
'61 Safari
http://airwave503.blogspot.com/
Airwave503 is offline   Reply With Quote
Old 01-31-2015, 06:11 PM   #2
DFlores's Avatar
1968 22' Safari
It looks like you put the insulation all the way around the end cap area, same as we did, we then had to remove some in places where it did not fit. I know you really don't want to hear this, but take down the end cap and find where end cap is denting the insulation and remove a layer.
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 01-31-2015, 07:27 PM   #3
Airwave503's Avatar
1961 22' Spaceliner
Portland , Oregon
DFlores, yes I did and I almost went with 1" thick boards to leave extra room but ended up rolling the dice with 1.5". Since only the side with the pex piping is off I am thinking that must be the culprit. There's only one layer but I can shave it down. Fortunately I didn't do too many rivets yet so not that much to drill out.
Will report back how it goes. Thanks.
'61 Safari
Old 01-31-2015, 07:31 PM   #4
DFlores's Avatar
1968 22' Safari
Get yourself some clecos and cleco pliers so you can test fit pieces, you will need them for the large upper skins as well
DFlores
David & Diana
Old 02-01-2015, 01:29 PM   #5
JRF0st3r's Avatar
1967 22' Safari
West Fork , Arkansas
I'll be in the same place soon so it's helpful to anticipate the problem.
Pex piping between the walls? If water piping, is that where it was found? Would it be easier to keep from freezing or to find and repair any leaks if it were inside of the inner wall?
JRF0st3r is offline   Reply With Quote
Old 02-01-2015, 03:11 PM   #6
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Heat will generally not affect fiberglass as far as pliability.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 02-02-2015, 08:03 AM   #7
Airwave503's Avatar
1961 22' Spaceliner
Portland , Oregon
Yeah, going with 1.5" foam board was a mistake. After shearing down a couple of high spots that I thought were the culprit I ended up tearing it all out. Then I could see that the hole were lining up and that the fiberglass protruded into the wall space in certain spots. Had to make some major mods and finally got everything lined up.
JR, I ran some pex from where I plan to put the H20 tank over my door to the future wet bath since there would be no clean way to hide it otherwise.
Hopefully the other end cap goes smoother.
'61 Safari
Does old fiberglass insulation equal new fiberglass insulation? Petethefeet General Interior Topics 7 11-14-2010 12:16 PM
New toilet holes don't match old holes RichHog Sinks, Showers & Toilets 8 03-15-2009 06:36 PM
Removing interior front endcap Mister Ed Ribs, Skins & Rivets 4 01-15-2009 09:17 PM
Interior Endcap Removal Proceedure? DanB General Interior Topics 2 08-17-2006 11:03 AM
Cracked Interior Endcap LuminumTraila General Interior Topics 9 03-03-2005 07:23 PM
