Old 12-05-2015, 04:58 PM   #1
Portland , Oregon
Reinforcement for New Cabinet Install
I have a 1952 Silver a Streak Clipper. Major rebuild. Finishing last of the exterior panels. My new interior plans include lots of new over window cabinets on both the curb side and street side.
I saw these at Colin Hyde's shop that he is using for 1950 era Airstreams. Also here is some of the same attached to the wall.Click image for larger version
ID:	253419Click image for larger version
There are some horizontal ribs on the curb side that are already there. You can see them in theClick image for larger version
ID:	253421 above the door arch. Click image for larger version
ID:	253422this was my starting point, so I don't have anything to refer to.
My question has to do with attachment devices, 5/32" blind rivets, attachment points, as should they have a rib to attach to or the interior skin only. This then gets more complicated as should I also add a vertical arched rib also. Hey to fab the cabinet carcass is cheap and storage is precious and my plans are for almost full length cabinets. This will be done in 30" widths. Limited by my 30" HF brake.
bikeukeguy is offline   Reply With Quote
Old 12-05-2015, 06:53 PM   #2
batman's Avatar
1964 22' Safari
modesto , California
You can double-up on the interior skins in areas you would like to mount cabinets and other things. That should give you the needed support without adding ribs, etc.
-Dennis
batman is offline   Reply With Quote
Old 12-06-2015, 12:35 PM   #3
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
You can add horizontal aluminum strips between ribs in the locations necessary before re-attching the interior panels. They will provide substantial mounting points.
SeeMore is offline   Reply With Quote
Mercedes GL receiver reinforcement hartusi Hitches, Couplers & Balls 18 06-26-2009 11:19 AM
Frame reinforcement - 1973 O'lander Lothlorian Repairing/Replacing Floor &/or Frame 2 02-10-2008 03:46 PM
Reinforcement of Frame Lothlorian Repairing/Replacing Floor &/or Frame 0 12-10-2007 05:15 PM
Reinforcement plate for 76 31ft. sovereign? chris's 67 Repairing/Replacing Floor &/or Frame 2 02-24-2007 08:38 PM
WBCCI Families & Youth - Positive Reinforcement LuminumTraila WBCCI Forum 44 07-18-2006 10:51 AM
