Old 06-15-2014, 08:13 PM   #1
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Rear Dent Repair...
I can't tell you how sickening it is to see that your Airstream has been hit by falling/flying debris. With the terrible storms we have been having in Pennsylvania I guess my number was up. The upper rear panel curbside took a direct hit and now we have a sizable dent to deal with.
We have several options that include replacement panel, removal inner end panel and roll out from behind, suction pulling from exterior, and paintless dent removal with hot glue/slaphammer. Before replacing the panel, I'll try one or move of the above techniques. This will be an ongoing thread and I'll post pictures as we try to work out the dent.
Indiana, PA
TAC PA-5
WBCCI 4871
ID:	214294   Click image for larger version
Roadrunner is offline   Reply With Quote
Old 06-15-2014, 08:34 PM   #2
1981 31' Excella II
New Market , Alabama
It depends on your desire for perfection. It will never be perfect if you try to repair the panel. It will be structurally sound. If you want perfect, I would replace the panel. If you can live with it being not perfect, then you are good.
Perry
Old 06-15-2014, 08:49 PM   #3
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
Good Luck.
To see the possible outcome: http://www.airforums.com/forums/f381...air-49308.html
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is offline   Reply With Quote
Old 06-17-2014, 08:25 AM   #4
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Pulling the Dent...Attempt 1
Perry...my "78" has plenty of imperfections, so I'm not looking for perfection. If I could achieve what Dan has done without removing the end cap I would be happy. So the logical way to proceed is to attempt to pull the dent out. I will attempt that later today using 2 1/2" and 4 1/2" suction cup pulls I got at HF for less that $9.00. We'll see what happens...
Indiana, PA
TAC PA-5
WBCCI 4871
Old 06-17-2014, 08:45 AM   #5
Gainesville , Florida
No insurance? Jim
dent repair on rear corner honez Ribs, Skins & Rivets 22 01-11-2008 05:21 AM
Dent repair? gflatt Exterior Restoration Forum 2 07-06-2006 09:53 PM
dent repair in oregon nevisstudio Ribs, Skins & Rivets 6 08-25-2005 11:40 AM
Dent Repair AccessMaster Ribs, Skins & Rivets 4 08-26-2003 05:35 PM
Dent Repair Jim W Ribs, Skins & Rivets 3 05-07-2002 11:43 AM
