Old 08-26-2005, 06:17 PM   #1
1978 31' Sovereign
Mesa , Arizona
Unhappy Rear corner body panel woes
Hi,
I own a 1978 31' Land Yacht. I pulled it out of my yard today and caught the rear awning arm on the corner of the gate. It pulled the arm completely out of the trailer, pushed in and creased the rear lower body panel right where it attaches to the straight segment of the trailer. I was actually pulling it out to take it over for an estimate to get the trailer fixed from a separated tire this past weekend. That said, I am also having an estimate written up for this damage as well. The gentleman that inspected the damage stated that the entire rear lower corner of the trailer will have to be replaced along with piecing in a small portion on the side of the trailer between ribs. He stated that the aluminum would not match due to the newer aluminum that Airstream is currently using. My questions to the forum are as follows
A. Is it possible for me to make this repair myself if I am pretty handy?
B. Is the panel made of a flat piece of aluminum or is the aluminum actually curved (specially fit for that part of the trailer)?
C. What is the scoop with the aluminum? I was planning on polishing my trailer this fall (bad clearcoat). Is there any aluminum available out there that will polish to a finish that is close to original?
D. Where may I find a new cap for a zip dee awning (the arm is in-tact, but the cap the attaches to the awning broke.
Any input would be greatly appreciated.
Slade Weaver
sladew is offline   Reply With Quote
Old 08-26-2005, 06:23 PM   #2
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Bad news
The end cap is a 3-D curve.
Call or email Zip-Dee for parts to replace your broken awning parts. They have great customer service.
You are probably out of luck on an exact match of the aluminum. There have been several changes over the years.
John W. Irwin
WBCCI #9632
Old 08-26-2005, 06:29 PM   #3
1978 31' Sovereign
Mesa , Arizona
Thanks John, Forgive my ignorance, but what do you mean by a 3-D curve?
Thanks, Slade
Old 08-26-2005, 06:35 PM   #4
Pahaska's Avatar
Hays County , Texas
Thanks, Slade
It is a compound curved piece, not a flat piece. Sorry to say, but you will have to procure it from the factory or from another source.
John W. Irwin
WBCCI #9632
Old 08-26-2005, 06:37 PM   #5
RichardT's Avatar
3-D would be 3 dimensional.
But from what you have described you did not damage the end cap, and the piece you speak of would be flat and You can get 2024 T-3 aluminum to match easy just like any vintage trailer as 78 was still full polishable aluminum.
Do a lot of reading and if you get the tools you can do this yourself.
Best of luck
Post some pictures for a for sure answer.
RichardT
RichardT is offline   Reply With Quote
Old 08-26-2005, 06:41 PM   #6
greg176's Avatar
Gabriola Island , British Columbia
If you get the segment from the factory it will be the same aluminum as original.The flat peice does not have to come from factory(use 2024-t3 aircraft aluminum).All will match after polishing.
greg176 is offline   Reply With Quote
Old 08-26-2005, 06:44 PM   #7
greg176's Avatar
I'm looking at a photo of a '78 Sovereign and that piece looks flat (no compound curve).
Old 08-26-2005, 07:02 PM   #8
Pahaska's Avatar
Hays County , Texas
RichardT
Read again.. He said that the end cap was damaged in addition to the flat side piece.
John W. Irwin
WBCCI #9632
Old 08-26-2005, 07:11 PM   #9
mkeith54's Avatar
1976 26' Argosy 26
New Florence , Missouri
Send a message via AIM to mkeith54 Send a message via Yahoo to mkeith54
For the Compound curve piece you could try Coclaw (sp) Salvage for a panel off a wrecked trailer of the same or near same year.
Mike Keith
75 Argosy 26'
96 Ford F-250 PowerStroke
mkeith54 is offline   Reply With Quote
Old 08-26-2005, 07:20 PM   #10
RichardT's Avatar
I read it, and I see nothing to lead me to belive he is speaking of the end cap.
Old 08-26-2005, 07:25 PM   #11
Pahaska's Avatar
Hays County , Texas
If that isn't the end cap, I don't know what is.
John W. Irwin
WBCCI #9632
Old 08-26-2005, 07:35 PM   #12
RichardT's Avatar
Please correct me if I am wrong.
The lower sections of the ends of the trailer are not compound curves. The upper "End Cap" is made up of compound curves as well as a non compound piece in the center. The interior "End Caps are behind these exterior "End Caps"
Mabye you are reffering to the Banana wrap? That is a compound curveand is made of a different grade aluminum.
Old 08-26-2005, 07:37 PM   #13
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
John, the end cap is on top, and those segments are compound curves. The panels on the bottom consist of one flat piece, one curved corner piece, and the banana wrap sections on the bottom. If the corner banana wrap is damaged, that piece is a compund curve, but is fairly easy to replace. Everything else is pretty easy to do.
Old 08-26-2005, 08:16 PM   #14
1978 31' Sovereign
Mesa , Arizona
Thanks a lot for the information. The corner panel that I damaged is the piece of aluminum that wraps around below the taillights and connects to the piece of aluminum where the rear hatch is located. I will take some pictures and include them in my next posting on this thread.
Slade
Solar Panel Installation 69Overlander Generators & Solar Power 28 03-03-2013 08:18 PM
Saggy Bottom ( rear end ) smily Repairing/Replacing Floor &/or Frame 127 10-01-2006 08:28 PM
replacement panel maznblu Ribs, Skins & Rivets 4 09-18-2002 05:45 PM
Dented panel replaced Jim W Ribs, Skins & Rivets 1 07-08-2002 07:07 PM
