11-20-2007, 10:09 PM
1966 26' Overlander
Conover
ready for rivets
My floor project is coming along on my 66 Overlander. I am ready to start going back together. I need to get some rivets ordered, but I am not sure what sizes/types to order. Reading the posts only confused me more. I need the beige rivets for the interior skin. Are these standard, or is there a specific length and diameter? I will need what seems to be slightly larger ones for the exterior and belly pan, and some olympics for the exterior that I had to remove to get the floor out. Is this enough info, or do I need to email Airstream? What sizes do I need, and do they have a specific name? And I guess while I am at it, what is the best source to get the rivets? Tom
11-20-2007, 11:53 PM
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake
Good luck on finding beige rivets. All I've ever found are the white ones.
Yes, you need various lengths and diameters. First, get the "big head" pop rivets from Vintage Trailer Supply to do the belly pan. I can't remember if they are 5/32 or 3/16, but whatever, they are the right ones. You only use these big head rivets on the belly.
Next you need lots of 1/8" pop rivets. 30% short, 50% medium, and 20% long. These are the standard sizes. Shorts are for two pieces of skin. Mediums will do when you have two pieces of skin and a rib. Longs are for everything else. You will find yourself using mediums when you should really be using shorts.
Also, make sure you have a handful of 5/32" pop rivets (not big head) for those places where the previous 1/8" rivet hole has been elongated/deformed. Drill it out to the next size and use the bigger rivet.
Make sure all your rivets are aluminum. The same sizes are available in steel and will cause galvanic corrosion. You can get the 1/8" rivets, in all three sizes, at most any hardware store. But they are in small quantities and expensive. Go with Vintage Trailer Supply (they are friends to the community) or Aircraft Spruce and Specialty. I'm sure you can Google other suppliers.
Zep
11-21-2007, 04:22 AM
1971 27' Overlander
Central
Was there ever such a thing as beige rivets or were they white and just yellowed over time.
11-21-2007, 06:37 AM
beige rivets .... how to
Simply stick a number of rivets in a piece of cardboard and spray paint them your favorite shade. Try not to paint the stem that breaks off as the paint can gum up the rivet gun.
11-21-2007, 08:07 AM
1973 23' Safari
1977 23' Safari
Palmer Lake
Originally Posted by jbond
... Try not to paint the stem that breaks off ...
All hail to the polishing King, but how the heck do you do that?
Zep
11-21-2007, 08:27 AM
1978 31' Sovereign
1984 31' Excella
Springfield
You might want to try going to Fastenal, a nuts and bolt store. I got all the hardware necessary to re-do our 78 sovereign there. At a reasonable price for rivets, screws, etc. They were comparable priced on the belly pan rivets and no shipping.
A good investment for re-doing an Airstream: an air compressor and an air operated rivet gun. I borrowed my brother-in-law's gun and it sure saved my hands! Also, no rebound like from a hand operated gun.
11-21-2007, 10:22 AM
More than one rivet loose
Los Alamos
aircraft spruce Home built and certified aircraft supply house.
Solid Aluminum Rivets from Aircraft Spruce
Michelle TAC MT-0
Sarah, Snowball
12-02-2007, 02:37 PM
1976 31' Sovereign
Missouri City
Originally Posted by thecatsandi
What hardware do you need to install the solid rivet?
Don
12-02-2007, 02:39 PM
Los Alamos
Depends,
Can to get a both sides? A rivet squeezer or a rivet gun and bucking bars. For a few rivets I would suggest goign to the airport and having an Aircraft mechanic do it for you. Slip him a $20 and call it good.
Michelle TAC MT-0
Sarah, Snowball
12-02-2007, 02:43 PM
1975 31' Sovereign
Canby
adonh, if your reference to "solid" rivets is the once on the outside sheel of your AS those a pop-tivets that have been shaved down. See Vintage for the shaver.
ted
