Old 07-26-2010, 06:17 PM   #1
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Question for the Shell Specialists
This weekends project is to install a Dometic Brisk Air A/C unit on the roof. The new opening is in and framed out with the headlining ready to put back in.
But as is usually the case, thereís a small glitch.
Sometime in the old girls past she was pulled under something a bit too low. Iím guessing tree branch. Well, most of the damage has been fixed, except for this springy area on the roof between the center and rear vents. Itíll pop up and down about ĺ of an inch. While the front of the A/C unit sits above a good roof rib the rear needs to be supported on, you guessed it, the soft spot.
No problem. Just put in a stiffener between the horizontal stringers. The issue is that this isnít an aluminum angle. Itís a thin stringer riveted to the shell with a snapped on rib. Iím certain that just installing the stiffener on the rib will cause it to pop off over the first bump.
I envision riveting through the stringer and rib before putting in the stiffener.
Hereís my question to the shell Gurus. Why would they design and install this arrangement? (In my biz itís a ďmanufacturing concessionĒ). Do you see any issues with riveting this assembly to the roof? Or am I over-engineering the thing and I should just drop the whole idea?
Thanks in advance,
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 07-27-2010, 07:11 AM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I don't think you are over engineering it at all. I would completely remove the snap together pieces along with the hat section and replace it with a bent up "Z" stringer and the put on the frame stiffener as shown.
Shell Off Help mbattin Repairing/Replacing Floor &/or Frame 11 07-13-2010 10:35 PM
Camper shell question Boondocker Tow Vehicles 10 06-01-2008 06:34 PM
How big a shell off has been done? tbrom Repairing/Replacing Floor &/or Frame 1 10-12-2006 09:45 AM
Shell on or off??? Bradjun1 Repairing/Replacing Floor &/or Frame 3 09-19-2006 11:19 PM
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 05:46 PM
