Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 11-22-2002, 02:00 PM   #1
Profile:
proper rivet gun for AS
What type of Rivet gun did Airsteam use back in the 60s-70s ?
We have a lot of Aircraft surplus stuff around here and I would like to look for the Proper gun
I do not think the small handheld pop rivet ones were used
Anyone of an archive picture of what it looked like ?
thanks for your help
oldvws is offline   Reply With Quote
Old 11-22-2002, 02:11 PM   #2
Profile:  LOST , Hawaii
Inside pop rivets were used, I don't think it would really matter what gun you use. On the outside skin the rivets are bucked, as long as the proper tool is used for the rivet head it should work. If you have anybody you don't like that hangs around, put them inside bucking for awhile, they won't be back.
John
74Argosy24MH is offline   Reply With Quote
Old 11-22-2002, 05:22 PM   #3
Profile:
I'm curious, how do you buck a rivet? (It sounds like the lead-in to a very bad joke.) It seems like the rivet machine would need access to both sides of the rivet at the same time.
Also, how does the holding power of an original bucked rivet compare to an Olympic rivet?
69Overlander is offline   Reply With Quote
Old 11-22-2002, 05:42 PM   #4
JPAIRSTREAM's Avatar
Profile:  1972 31' Sovereign
, Ohio
Images: 47
rivets guns have a head that is cut to the shape of the exteriour rivet. the guns that are used are like a jack hammer they go in and out at a high speed..So when you put the gun on the rivet and a person on the inside with a flat hard tool that pushes gently on the back side of the rivet it flattens out. this is held in your hand and you push out all manual. If you over due this and make rivet to thin on the inside it is weak. so there is alot of feel to doing this.
rockwell used to make a gun and you custom made the heads.
Not a very good writer so please bare with me..
Olympic are a replacement rivet they are shaved to appear to be like a standard rivet. It is good repair but will never be as good as a Bucked rivet.
JP
JPAIRSTREAM is offline   Reply With Quote
Old 11-22-2002, 07:01 PM   #5
Properly installed rivets are the best fastener there is. Besides clamping the 2 pieces together, they expand to fill the hole, no chance of the panels, plates, etc. moving. Olympics might be good, but I doubt if they have the fastening power of a bucked rivet.
On narrow pieces of metal you can use an air/hydraulic yoke which looks like a giant 'C' clamp to compress the rivets. Things like bodies would require too much depth so you use a tool which looks like an air chisel and a bucking bar inside. It is noisy work, your head rattles for hours afterwards.
John
Old 11-22-2002, 09:50 PM   #6
Profile:
Rivets and tools required
Rivets.........are a very simple yet complex fastening system. The understanding of aircraft rivet systems is VERY complex and is governed by many rules and standards. I've forgotten what I once knew. Here are a few pics of tools for the aircraft world. The RV world is similar but very different.
Name:	small rivet gun..screw extractor.jpg
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Old 11-22-2002, 10:02 PM   #7
Profile:
Rivets
Many sizes and shapes..
Name:	solid rivets2.jpg
Old 11-22-2002, 10:04 PM   #8
Profile:
Rivet bucking bars
From Lookheed salvage 25 years ago
Name:	bucking bars3.jpg
Old 11-22-2002, 10:07 PM   #9
Profile:
AC tools
A rivet driver 3x power....safety wire install pliers....sheet metal burr remover
Name:	aircraft tools.jpg
Old 11-22-2002, 10:10 PM   #10
Profile:
Rivet drivers..smoothers... finishers
Drivers for rivet tool. Many designs used..
Name:	rivet bumping tools3.jpg
Old 11-22-2002, 10:14 PM   #11
Profile:
Clecos plier type
These devices are designed to hold panels and parts in position as parts are attached, drilled, and fitted. Other types are available to be used with wrenches.....
Name:	plier operated cleco.jpg
Old 11-23-2002, 06:18 AM   #12
Les Gilliam's Avatar
Profile:
Frank,
Boy, did you bring back mamories! Between high school and college I worked for two years at Boeing in the wing assembly plant. My job was to assemble parts and prepare them for riveting, so I worked right next to where the riveting was going on. I am lucky I still have my hearing. Wish I had kept some of the old tools.
Les
Les Gilliam is offline   Reply With Quote
Old 11-23-2002, 09:04 PM   #13
Pick's Avatar
High Springs , Florida
Images: 36
I was told on Thursday, during a tour of the AS plant that the rivets they are using now have "O" rings on them, to seal the connection. Did not get to see any of them, though.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Pingbacks are On
rivet tools maznblu Ribs, Skins & Rivets 12 05-31-2006 05:51 PM
Ebay rivet shaver TomW Ribs, Skins & Rivets 4 02-26-2004 01:54 PM
Rivet Removal pap Ribs, Skins & Rivets 11 02-06-2004 10:04 PM
Rivet gun overlander76 Ribs, Skins & Rivets 1 08-03-2003 06:22 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
