Old 05-30-2014, 03:16 PM   #1
Anchorage , Alaska
Proper Diameter Rivets to Attach Shell to "C" Channel
I know I could tease an answer to this question this out of the archives. I originally researched this question a few years ago. I am picking the project back up after a few years, and I am not sure I trust my notes.
I am about to reattach the shell of a 1963 Bambi to a new "C" channel and belly wrap. In my notes, I have that the original exterior rivets are 1/8" diameter, but with a somewhat oversized head, when compared to current rivets.
The closest rivet currently available, that will match the original is a 5/32 diameter.
Can anybody confirm?
Aktundra is offline   Reply With Quote
Old 05-30-2014, 03:41 PM   #2
The shell was buck riveted to the "C" channel, using 1/8 diameter buck rivets, which do have a large head.
Old 05-30-2014, 10:07 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Go for it. No harm in using the 5/32 rivets.
Old 05-31-2014, 03:25 AM   #4
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Go to the vintage trailer supply and look they have them in bulk and if you need to go up in size then they have them also. Have a great day and are there some pictures? Maybe just a couple so we can get a good look at your girl (airstream). Thanks
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 06-01-2014, 09:37 PM   #5
Anchorage , Alaska
I think I will go with 5/32 AD's to reattach the shell. They are low, somewhat obscure, and most are covered by the end wraps. Besides, there are probably a handful of people in the country that could tell them apart (and hopefully none here in Alaska) !
If I learn my chops, and get some confidence, may take on a much larger project for the front window replacement, and then exact match to the existing rivets would be more noticeable
Name:	window mock-up.jpeg
Old 06-03-2014, 12:27 PM   #6
1964 22' Safari
Grand Forks , North Dakota
Nice idea for front window(s).
adds to the "porthole ship" effect.
DakotaWind is offline   Reply With Quote
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 12:53 PM
Attach U channel without dropping belly pan? thinktankair Repairing/Replacing Floor &/or Frame 7 03-23-2014 02:55 PM
7" diameter tail light back plates Rosemary Lights - Interior & Exterior 10 04-15-2011 05:56 PM
Adding an electric jack to 2005 Bambi -- what diameter? platbr Jacks, Stabilizers, Lifting and Leveling 1 09-27-2005 03:40 PM
