Old 09-19-2012, 10:23 AM   #1
Eagle & Bear's Avatar
1976 29' Ambassador
Madison , Officially SD but are traveling full time.
Problem with Olympic rivets
I have been repairing and refinishing the outer shell. When I attempt to use an Olympic rivet (on two 0.032 sheets) the stem breaks inside of the rivet on the second squeze. There is no stem left sticking out. I am using a # 21 drill.
Anyone else have this problem? I have had the rivets sitting around for about two years. I doubt if they have an expiration date but was there a recall on the Olympics that I missed?
Eagle & Bear is offline   Reply With Quote
Old 09-19-2012, 10:32 AM   #2
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
I have had this problem before. I found that one of the legs that spread out hit an obstruction such as a rib. I just put another one in noting the orientation of the legs . I put the slit towards the obstruction and the problem was solved
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 09-19-2012, 11:27 AM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
I've also had the same problem, and the same fix as Anthony mentions above. Try drilling it out again, and changing the orientation of the slits or legs of the rivet by 1/4 to 1/3 of a rotation and try again. Might take a couple of tries to get it oriented correctly so the legs can expand inside.
Old 09-19-2012, 11:28 AM   #4
Ottawa , ON
Or if you can't orient the rivet to make it through, you can remove a leg to achieve that.
Old 09-19-2012, 11:53 AM   #5
1976 29' Ambassador
I rotated the rivet about 1/8 turn. It woked!! Thanks everyone. I thought that somehow I had bought a set of defective rivets.
Old 09-19-2012, 12:10 PM   #6
1977 Argosy 24
Milltown , Wisconsin
Now that's the kind of excellent information that you can only get here on Air Forums.
ventport is offline   Reply With Quote
Old 09-19-2012, 01:07 PM   #7
1976 29' Ambassador
...and fast too.
