Old 02-18-2010, 07:33 PM   #1
fotochop's Avatar
1969 23' Safari
New Orleans , Louisiana
Images: 18
Pro Quality Dent Puller?
having tried the $1.99 Harbor Freight version to no avail, I'm hoping someone may be able to point me to a high-quality dent puller, suction-cup, that might be able to work on this big soft dent in the rear of my rig:
any info appreciated..
fotochop is offline   Reply With Quote
Old 02-18-2010, 08:12 PM   #2
TWaugh's Avatar
1969 25' Tradewind
1971 18' Caravel
Images: 8
Ding King, but I'm not sure it will work effectively on an indentation that size. Maybe if you worked in stages around the indent.
I too tried suction tools without much luck. I ended up removing the inner shell and then worked it out by hand. Needless to say, that is an extreme task.
DingKing.tv | Home
Tom Waugh
Tom
Res nolunt diu male administrari.
WDCU Unit #170
Air #7085
TAC VA-4
WBCCI #2641
VAC
71 Caravel
69 Tradewind
My YouTube Channel
TWaugh is offline   Reply With Quote
Old 02-18-2010, 08:14 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I had big dents in the rear of my Trade Wind on above window where someone in the past had backed it under a garage that was just a little low. I tried all the tricks that are posted on various forums and nothing worked. The aluminum in the shell is just too thick and tough to work like auto sheet metal. Since I was doing the bath and had the interior out, I removed the fiberglass end cap in the bath. I next had a guy who does the paintless dent repair at the local car dealership come by. He had fixed a couple of big dents in my daughters Accord and his work is amazing. The aluminum just would not work. He could not get enough leverage to "move" the metal. Don't waste time on that idea. The last resort was the old fashion way, very carefully using dollies and body hammers (Harbor Freight has them), I very gently worked the dents out. I had several creases that would not just push out. You will need someone on the outside to hold the dolly. It is tricky and you can make things worse if you are not very careful. A quick glance and you won't see my dings, close inspections you can but few people every notice.
Good luck.
Old 02-18-2010, 08:25 PM   #4
fotochop's Avatar
1969 23' Safari
Images: 18
thanks, TW, I'm only considering it because there's a blog video in cyberspace from this couple that's fulltiming and the guy's father in law fixes this pretty substantial dent with a suction puller....dude makes it look so easy its crazy! ...but, yes, I know its gotta be tougher...
I had my lower bath out a year ago but just didn't have the jam to pull the upper cap out at the time (I was on the verge of AS burnout ;-)....now I'm wishing I had taken a breather and pulled the cap...
I also have an even bigger dent (with creases) in the front that looks like it may require full panel replacement...ugh...
Old 02-18-2010, 09:30 PM   #5
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
how about renting or borrowing an glass suction cup? Also check with the body shops, I seem to recall someone using a hot melt type glue to attach small tabs onto surfaces and pull dents that way, glue then could be heated up slightly and popped off without leaving marks on the metal.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 02-18-2010, 09:43 PM   #6
2008 28' Safari
Seattle , Washington
I found an 18" dent on the rear corner of my 08 one morning and bought two of the Harbor Freight 4" ($4 or $5 each) suction cups. I sprayed some cooking oil on the area to increase the effective suction and used both suction cups at the same time. I actually was pleased at how well the dent popped out.
Dave Hartley
Seattle
hartusi is offline   Reply With Quote
Old 12-15-2010, 05:11 AM   #7
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
I think that was ROYCE. Haven't seen him post for awhile.
I've had some success with the Harbor Freight cups. They work great if the shape of the dent allows them to get a grip.
Zep
Old 12-15-2010, 08:54 AM   #8
Yhottys's Avatar
1960 24' Tradewind
1961 16' Bambi
Oakland , California
Body Buddy?
We're thinking about purchasing the Body Buddy to pull out an intractable front curbside dent on our 1961 Bambi. Body Buddy Vacu-Dent Pneumatic Dent Puller
At $199 it's not cheap, but we've heard great things about it. We believe a member posted his experience with it on a similar thread.
However we've had incredible results using a suction cup similar to the image below. It helps to work on the dent when it's hot outside, or use a blow dryer at its maximum setting to heat up the aluminum, making it easier to manipulate. We pulled out a dent on our 1974 Tradewind similar to yours using it.
Good luck! Please let us know how things work out.
Gemma and Murray
Yhottys is offline   Reply With Quote
Old 12-15-2010, 09:36 AM   #9
I have been looking at these and like this one better...
Klutch Pneumatic Dent Puller | Auto Body Tools | Northern Tool + Equipment
Old 12-15-2010, 09:46 AM   #10
Chasmorgan's Avatar
1999 23' Safari
I've used the Harbor Freight product with great results. Put a little water on the cup and the grip was enough to pull out a 12 inch divit! I agree that this is better done on a warm if not hot day. The result was not perfect but hard to detect unless you were looking for it.
Charlie M
TAC TX-6
Chasmorgan is offline   Reply With Quote
Old 12-15-2010, 09:53 AM   #11
Check out my post asking for before and after pics.
There is a similar dent in the rear cap of one of them that came out pretty well.
I also just found that Klutch dent puller on Ebay cheaper...
Old 12-15-2010, 11:55 AM   #12
2008 16' Safari
Destrehan , Louisiana
I bought a cheap vacuum type dent puller at Autozone and then connected it up to a 1 hp Gast vacuum pump. Spread on some KY jelly to get a good seal and was able to pull several good size dents out.
The trick here is to just have a 1 hp vacuum pump just laying around the house.
dlb435 is offline   Reply With Quote
Old 12-15-2010, 12:40 PM   #13
SRW
TEXAS66
SRW's Avatar
Georgetown , Texas
Smile The Body Buddy Vacu-dent
Try the Body Buddy Vacu-dent.
I have seen it work and it did a surprisingly good job on dents in several different Airstreams.
It requires a source of 85psig compressed air (strangely enough).
You can find it online at:
Auto Body Toolmart - Paint Booths, Shop Equipment, Dent Repair Tools
for about $200
TEXAS66
SRW is offline   Reply With Quote
Old 12-15-2010, 04:25 PM   #14
ALTE797's Avatar
1999 30' Limited
Port Perry , Ontario
I seem to recall a thread with a similar dent that was repaired by heating the dented area until it popped out !
ALTE797 is offline   Reply With Quote
Pro-flamingo? Why or why not? Stella Fun & Games 32 04-13-2008 10:18 PM
Important upgrade - Cap Puller Janet H Exterior Restoration Forum 9 04-18-2004 05:45 AM
'89 345 Limited Edition diesel puller Astrodokk Airstream Motorhome Forums 13 06-18-2003 05:33 PM
Airstream Puller - with Ford TD FrankR Tow Vehicles 0 05-16-2002 10:45 PM
Ford Diesel RV Puller 3 axle FrankR Tow Vehicles 0 05-03-2002 06:47 PM
